Author Topic: New project started: Irrawaddy paddler "Mindon" 1948  (Read 44290 times)
Re: New project started: Irrawaddy paddler "Mindon" 1948
« Reply #90 on: June 03, 2020, 01:53:51 PM »
 :bravo :bravo :bravo :bravo :bravo :bravo :bravo
« Reply #91 on: June 04, 2020, 06:35:44 AM »
Today I found in my stock an steam regulator with spherical cone - which wasn`t tight I knew. But the work wasn`t too much for grinding up (?) the cone with tooth paste until it was completely tight. When the weather on sunday will be good, I will drive with "Mindon" to a ship model club in Blackforest.
« Reply #92 on: June 04, 2020, 06:39:03 AM »
Sorry, quality of the pictures seems rather bad - I don`t know the reason.
« Reply #93 on: June 28, 2020, 01:00:12 AM »
It looks very nice on the water!
Could you please explain what was wrong with the 1:1 gearing ratio and how you changed it?
« Reply #94 on: July 01, 2020, 04:23:13 AM »
The gearing ratio of 1 : 1 was not wrong, but even not ideal. The load for the engine was rather high and even the steam consumption. This results in a rather low possibility to navigate the engine in a sensitive manner from very slow to full speed. The negative effects were more obvious at the "Presto" with her 120 mm diameter wheels. The "Mindon" with her small 90 mm wheels seems better,  but even not really good. The gearing ratio at "Mindon" now is 1,5 : 1, obviously this is the better alternative for more exact engine navigation.
« Reply #95 on: July 05, 2020, 06:02:34 PM »
I see what the problem was and I agree it is important to be able to run the engine slowly.
But of course,  the slow running ability is partly given by design but even more by the internal friction and possible internal steam losses.
« Reply #96 on: September 12, 2020, 01:42:42 AM »
Some new pictures today, a nice sunny late summerday,
« Reply #97 on: July 20, 2026, 09:21:20 PM »
Dear friends and neighbors,
at 17.7.26 again some pictures of Irrawaddy paddler "MINDON". Pictures were taken at the little lake beside young Danube. Presentation was good - but only at this part of the lake, because big areas of the water were full of aquatic plants. Hope, you will enjoy the pictures!
« Reply #98 on: July 22, 2026, 06:27:03 AM »
Very smart Thomas........ :bravo
We see the long steering rope/wire going Aft along the Portside deck from the low brown hatch, however it is difficult to see the actual rudder pivot
Again, crystal clear waterway
