New project started: Irrawaddy paddler "Mindon" 1948
5
6
7
Topic: New project started: Irrawaddy paddler "Mindon" 1948 (Read 44290 times)
Hankwilliams
Re: New project started: Irrawaddy paddler "Mindon" 1948
Reply #75 on:
October 03, 2019, 01:47:28 AM »
it`s the steam steering engine above the crew`s quarter. I don`t know why the steering engine was at the rear of the ship (in opposit of the "China", where it is fore), but in accordance to the plan it`s correct. The later Irrawaddy steamers also had a rudder house with bridge above the fore roof, this would be the normal way to steer the boat. And this will be the last bigger work at the model by me.
Hankwilliams
Reply #76 on:
October 07, 2019, 11:38:20 PM »
The big roof is now finished. Like the "China" I made the roofing with fine 400 sand paper. The last two days the pilot bridge is built, so I suppose to finish the boat until beginning if next week. Weight of the boat is now 6,4 kg, may be that the model will dive little deeper than the waterline.
Paddlemex
Reply #77 on:
October 08, 2019, 04:02:06 AM »
Looks great Thomas.
How do you make the supports "show" through the roofing. Did you sand something to make those lighter stripes?
Will the Friedrichshafen meeting be at the Messe fairground or will be actually sailing on the lake?
Jurgen
Hankwilliams
Reply #78 on:
October 08, 2019, 08:37:04 AM »
Thanks Jurgen. The roofing stripes are irregular grinded sandpaper stripes. I think the result is quite realistic and similar like in the videos of the Bangladesh rocket steamers. I will perform the boat at Friedrichshafen Messe together with the big "China" and the blockade runner "Hope" - and also the "Fulton`s Folly", lying on the trailer. In "Maschinen im Modellbau" this week a long article about the Folly will be published.
I don`t know, whether there is enough time to do a trip with "Mindon" at the lake before, but in every case I must make some test runs in the water tank to be shure of a good performance without breakdowns.
kno3
Reply #79 on:
October 12, 2019, 09:37:07 AM »
Very nice work!
Hankwilliams
Reply #80 on:
October 13, 2019, 08:06:39 PM »
The model is nearly finished. I `ve altered the paddlebox mirrors now like there is at "Myat Yadana" - in the original plan there was only a wall with two fake windows. I think, the apperance of the boat with the vents now is more attractive. A problem are to make the 4 vents to the engine/boiler room. Vents in this size are out of trade, may be I will make them with copper tubes and angles.
Next week some test trials in the water tank are necessary, but I expect no major problems.
kno3
Reply #81 on:
October 13, 2019, 08:29:20 PM »
An impressive ship, should look great on the water.
Hankwilliams
Reply #82 on:
October 17, 2019, 07:17:05 PM »
I made several test runs with the boat in the test tank, in the beginning some problems were visible: The new steam regulator wasn`t allright, far too less steam came to the engine. I replaced it by an old one, what is slightly leaky. Then one feathered wheel was jaming. Today in the morning the whole installation seems ok, but some further test runs are necessary to avoide breakdowns at the steam meeting in Friedrichshafen in two weeks. The nautic stability of the model is good, also you can see that the draught is only some millimeters more than the waterline.
Hankwilliams
Reply #83 on:
October 18, 2019, 07:44:55 AM »
Not to forget a problem of water tightness. Between paddleboxes and sponsons deck was a gap. When the wheels are turning, water comes via this gap into the hull. I have tighten this zone with sillicone - hope this problem will be solved tomorrow. Engine and wheels seems ok now.
Hankwilliams
Reply #84 on:
October 22, 2019, 03:47:02 AM »
It seems, that now all functions are well. The paddleboxes are no more leaking and the engine is running well. I`m waiting now for four fans for installation behind the funnel and the rear enigne area. I made the flag of Myanmar Inland Water Transport, the 1948 successor of Irrawaddy Flotilla Company. I also add some pictures for illustrating the draught of the boat.
Reply #85 on:
October 22, 2019, 07:22:03 AM »
The four fans Thomas?........for improved combustion, or everything getting too hot?........... Derek
Paddlemex
Reply #86 on:
October 22, 2019, 10:41:21 AM »
Also puzzled regarding the fans.
Cooling or fresh air supply?
Jurgen
Hankwilliams
Reply #87 on:
October 22, 2019, 06:53:48 PM »
May be, I didn`t write the correct expression - I mean the funnel-shaped, right-angled tubes for fresh air supply to boiler/ engine room. In german language "Drucklüfter". What is the correct expression?
Paddlemex
Reply #88 on:
October 23, 2019, 02:13:41 AM »
In an old bilingual Graupner catalog they are called "pressure vents". However, looking that expression up in Google does not render anything similar to what we are talking about.
Ventilator cowl seems to be better. The native English speaking forists probably can tell us the correct name of this device.
Interestingly during my search I found the "Dorade vent" which is a box installed below the cowl to separate water from the air that is fed into the interior of the ship. The name comes from the Dorade yacht where this design was used for the first time in the early 1900s.
Hankwilliams
Reply #89 on:
June 03, 2020, 02:32:41 AM »
A sunny warm day with blue sky - a good time for maiden voyage of a new steamer! "Mindon" shows a good presentation - although three minor alterings were necessary. The gear reduction engine to paddleshaft with nearl 1 : 1 wasn`t sufficient and the rudder deflection was too less - this I made in the afternoon. The steam regulator wasn`t tight, so I had to control the engine by Hackworth gear - a new Regner regulator is ordered.
5
6
7
