Author Topic: DUKE OF DEVONSHIRE  (Read 340271 times)
Re: DUKE OF DEVONSHIRE
« Reply #360 on: November 02, 2010, 01:29:11 AM »
A unique feature on the Duke and Duchess of Devonshire was the gang plank mounted on the bow. So it just has to be added. The wire gallows brackets will have to be made to look like angle iron later. Don't tell Ronald Mc I have his stirring sticks. Geoff
« Reply #361 on: November 02, 2010, 01:33:04 AM »
Picture of said gang plank. Geoff
« Reply #362 on: November 03, 2010, 02:37:25 AM »
" Don't tell Ronald Mc I have his stirring sticks."
I knew there had to be something there that was useful.
Regards.
« Reply #363 on: November 03, 2010, 06:51:13 AM »
Regards.
they're good for mixing paint/araldite/GRP resin too!  ;D
« Reply #364 on: November 03, 2010, 08:19:40 PM »
I also used the sticks (cut in half ) for the top layer of the gratings. The bottom layer from the packs I purchased. Twice as big a area . I am a cheap skate. Geoff
« Reply #365 on: November 05, 2010, 04:41:19 AM »
The gang plank in position. Raised and lowered. Don't think I will make it radio controlled as I hope I will not be running up on an beaches. Geoff
« Reply #366 on: December 03, 2010, 01:57:22 AM »
A little more detailing completed. Geoff
« Reply #367 on: December 07, 2010, 09:46:21 PM »
This is just for you Derek I'm sure I am still being watched. In the thread on the boiler build I proposed to place the separator in the top of the boiler. My thoughts being,  that the oil from the engine along with any condensation would vaporize, increasing the smoke-steam from the funnel. The question now is would steam oil vaporize at this temperature? In the photos although it doesn't look like it the bottom of the separator is sealed by a plate. The 1/4" pipe will go up the chimney. the long 5/32" from engine and the short 5/32" is for emptying the separator. That is if the experiment doesn't work. Geoff
Offline PeeWee
« Reply #368 on: December 08, 2010, 03:31:14 AM »
Well it looks like i may not have done much since the Paddle day but it looks like you have been going great guns.  looking very nice there
« Reply #369 on: December 08, 2010, 06:37:44 AM »
Hi PD's....& RGY asks... "would steam oil vaporize at this temperature?"   :o
mmmmmmmmmmm . = I think the exhaust steam will be carried up by the boiler gas draft...however the residue oil may  condense & fall as droplets of oil back down into the top of the boiler  :-[
This may the spit & smoke....but also if enough in volume will form an oil skin on the boiler internals which may in turn create hot spots.... :crash
1. Maybe the best way is to get a frying pan on the kitchen stove @ approx 150 degrees C & add a few drops of steam oil & note what happens... :goodluck :oops :sorry but :shhh your good wife prior to your experiements
2. GOOGLE...the flash point of Grade 460 steam oil
TK 460 TK 680
ISO Grade 460 680
Density, kg/m3 923.0 923.6
Viscosity
cSt @ 40°C 429 627
cSt @ 100°C 30.1 37.8
Pour Point, °C -7 -7
Flash Point, °C 271 279Compounding % 5 5
AGMA Grade No. 7 Comp 8 Comp
Derek :beer
« Last Edit: December 08, 2010, 04:34:04 PM by derekwarner_decoy »
« Reply #370 on: December 08, 2010, 11:39:34 PM »
No Derek where we are at cross purposes is it is a water tube boiler. If anyone else is looking the drawing will explain. Good idea, I will experiment to see the temperature steam oil will vaporize. Geoff
« Reply #371 on: December 18, 2010, 08:13:09 PM »
Eddy you will be pleased the splash guards are fitted. Geoff
« Reply #372 on: December 18, 2010, 08:18:58 PM »
Well done Geoff, almost at the stage where some on the water testing can be done! Mind, if your local sailing water is like ours, you'll have to fit skis! Our lake has about 6" of ice on it :(
« Reply #373 on: December 24, 2010, 09:08:51 PM »
Just wishing everyone a merry Christmas. :beer :06 and a Lucky new year. Thank you for following my build. Geoff
« Reply #374 on: February 09, 2011, 04:45:20 AM »
Just had a small success. My daughter had decided to get married church and hotel booked!!! :sobbing Why cry that is supposed to be the mothers job. Sept 3th, no good for me, as that is the day I will be on my way to PADDLE DAY 2011. Well the shot gun worked, so the big day will be 14 May. :beer  All I have to do now is get the Duke sorted. I know traction engines aren't even able to float, but that is what I've been doing since christmas. R.G.Y.
