DUKE OF DEVONSHIRE
22
23
24
25
46
Topic: DUKE OF DEVONSHIRE (Read 339982 times)
djcf
Re: DUKE OF DEVONSHIRE
Reply #330 on:
October 04, 2010, 07:52:49 AM »
Hi Geoff,
Good to see the enthusiasm...she will be ready for next paddler day
(thats my deadline for my build!)
Found this part of a plan for Duchess of Fife.... doesn't show to much detail, but there is some sort of chain stop, maybe the "Duke" had a similar set up? If I get stuck for a detail, I look at similar vessels for a clue.
Will let you know if I find any pics etc
Reply #331 on:
October 04, 2010, 08:18:21 AM »
Geoff,
Normally the anchor chain would come up through a hawser on the side of the hull, then the chain would run across the deck to the anchor winch/capstan, and from there down another pipe into the chain locker below....
Hope that helps?
Reply #332 on:
October 04, 2010, 10:06:45 AM »
Hi PD's......
...Geoff.....in your snaps pict0031.jpg & pict0002.jpg you display the earlier variant of a hawser pipe which is simply a robust cast iron horizontal reinforcement ring forged back into the [in this case] cast iron bulwark plates on either side of the bow sprit
Then as Eddy suggests ....."
then the chain would run across the deck to the anchor winch/capstan, and from there down another pipe into the chain locker below"....
You have correctly displayed two of these ....robust cast iron horizontal reinforcement ring
....as one was used for mooring ropes & the other usually the anchor
You need to ensure that [in a plan view] the anchor chain has a 180 degree turn/bite on the winch/capstan drum....this will naturally off set the entry point to the chain locker.....
If fordeck space permits...
....you could also add a chain stopper which locks
the chain just outby of the cast iron entry point to the chain locker .....
...but naturally this stops the anchor+chain from paying out......
when underway.........Derek
Last Edit: October 04, 2010, 10:12:26 AM by derekwarner_decoy
Reply #333 on:
October 04, 2010, 10:21:36 AM »
mmmmmmmmmmmmmmm....just thinking here PD's
.......did the DoD actually have an anchor chain...or did the crew simply hoist the anchor via the rope block & tackle as shown at the bow
...I don't know
.....Derek
Last Edit: October 04, 2010, 10:25:53 AM by derekwarner_decoy
Reply #334 on:
October 04, 2010, 02:32:12 PM »
RGY....just a guess here.....
.... couldn't find a snap of DofD with an anchor......but here is a snap of PS Consul
....not sure....could there have been a rope hand winch for the anchor on the forecastle that the crew simply would wind in or let out?
....& then the anchor it self secured with the chain when heaved in & stowed away? ...or as per the snap?
R.G.Y.
Reply #335 on:
October 04, 2010, 08:01:54 PM »
Thank you all for your thoughts.
There is very little space at the bow which is what started me wondering.
I tend to agree with Derek (just for once
) the rope idea seems right. As the design was very old fashioned even for 1890, and a lot of features correspond to west country schooner practice. Also as Derek said there are no pictures showing a chain going over the bulwarks. It would be rare for Duke to require an anchor, landing at piers or on the beach. Except the kedge when run up on the beach, for which piles of rope can be seen. Off course the Consul had 2 rebuild by the time of the photo. Geoff
Last Edit: October 04, 2010, 08:04:46 PM by R.G.Y.
Reply #336 on:
October 04, 2010, 09:02:48 PM »
Oh dear PD's......
....RGY says......
"it would be rare for Duke to require an anchor"
.......surely British mercantile laws would have required such a fine vessel of ample tonnage to have [had] an anchor to avert a risk of life in an emergency circumstance.......... whilst all the fare paying passengers
were slipping their G&T in the saloon bar.......
BTW... Geoff.....what is the kedge/a kedge?...........Derek
Last Edit: October 04, 2010, 09:05:55 PM by derekwarner_decoy
R.G.Y.
Reply #337 on:
October 05, 2010, 01:21:28 AM »
Derek, I am not suggesting there would be no anchor at all !! After I agreed with you as well
). May be I should have said use an anchor. Just that it would be secured inside the bulwarks, with out the rope or chain connected permanently. As for a kedge ( may be I can't spell) is a smaller anchor usually deployed from the stern. On the duke and Duchess used to hold the ship square to the beach when driven ashore to embark or disembark passengers. A very dubious practice which wrecked the Duchess, as you probable know. BWT Whats G&T we drink scrumpy (proper zider) in the west country. No one cares whats happening after a couple of pints.
G EoF f
faery
Last Edit: October 05, 2010, 01:30:53 AM by R.G.Y.
mjt60a
Reply #338 on:
October 05, 2010, 02:15:45 AM »
don't know for certain but I would expect something like this..
mjt60a
Reply #339 on:
October 05, 2010, 02:19:43 AM »
so far as I can tell...
the screw handle next to the chain is to lock it so it can't slip and the lever to the right disengages the chain sprockets so the windlass can still be used with ropes (for mooring)
on older ships where the anchor doesnt fit into the hull (picture is from tattershall castle, where it does) the anchor seems to have been lifted onto the deck using a davit, if it wasn't likely to be needed...
Last Edit: October 05, 2010, 02:23:23 AM by mjt60a
R.G.Y.
Reply #340 on:
October 05, 2010, 07:55:02 AM »
Thanks Mick but I do know there is only a steam capstan on Duke, Both forward & aft. As I have said she was very old fashioned. Geoff
R.G.Y.
Reply #341 on:
October 06, 2010, 02:57:18 AM »
The boss gave me permission to buy her present for me on my birthday . See P1)
So I have had a play. Made the navigation lights. Started with 7/16th brass hexagon bar. Turned out of center ( to lazy to change to 4 jaw chuck ) so packed one jaw. P2) The lamp in the photo is the stern light so I kept the round section, milling off the remainder of the hexagon and drill 1/4in hole in the flat. Finish machining by parting off an drill hole in center of the bottom to fit LED. P3) The mast head light made the same with 1/16th tube soldered on each side. P4) Port & starboard had 2 flats @ 90 deg: The complete set in with the source of the LEDs P5)
Last Edit: October 06, 2010, 06:11:11 AM by R.G.Y.
R.G.Y.
Reply #342 on:
October 06, 2010, 03:11:25 AM »
Lost the photo of the finished items here it is. after painting the red & green on the LEDs i set them in clear bath silicone. This is smoothed in with a coffee stirring stick, then smoothed off & the excess using a rag dipped in white spirit. Geoff
Last Edit: October 18, 2010, 03:04:04 AM by R.G.Y.
R.G.Y.
Reply #343 on:
October 06, 2010, 10:50:42 PM »
Last post for 10 days, off to Las Vegas.
But I have the filigree sorted. Cut out of an old box. Geoff
mjt60a
Reply #344 on:
October 06, 2010, 11:47:42 PM »
very impressed with the lights, mine are much more basic - just brass tube with a square hole filed in one side and a piece of styrene stuck in the top...
22
23
24
25
46
DUKE OF DEVONSHIRE
