DUKE OF DEVONSHIRE
3
4
5
46
Topic: DUKE OF DEVONSHIRE (Read 339978 times)
PeeWee
Re: DUKE OF DEVONSHIRE
Reply #30 on:
January 13, 2010, 05:58:12 PM »
Looking good there, nice solution to the shaft problem. I must get back inbto the workshop and restart my projects.
R.G.Y.
Reply #31 on:
January 14, 2010, 07:58:16 AM »
Thanks Ian I was quite Chuffed myself. Of Course I could have got a 8mm rod turned off .5mm then bushed the bearings, But I like to use what I have.
I hope I have inspired you back into your workshop. Geoff
R.G.Y.
Reply #32 on:
January 21, 2010, 07:17:13 AM »
Paddleducks, still quiet! Are you all in your workshops? I have just managed an afternoon, made the blocks to hold the bearings, the collar to strengthen the joint in the shaft and turned the hubs for the wheels. In the photo can be seen an extra bearing, fixed to a pillar it is extra support next to the eccentric for the boiler water supply pump. this is still in production. In the mean time the hull is almost planked pictures soon. Geoff
Last Edit: January 21, 2010, 09:58:42 PM by R.G.Y.
Reply #33 on:
January 21, 2010, 09:00:34 AM »
Good to hear your making progress Geoff, I think everyone else on PD's has either gone into hibernation for the winter, or those in the southern hemisphere are on their summer hols!
R.G.Y.
Reply #34 on:
January 21, 2010, 10:19:33 PM »
Hull planking I was tempted to keep these pictures secret! the job looks so rough. Quarter inch balsa doesn't bend to well, so a lot of sanding will be required. Why use balsa? I believe lightness is the key to a sailing model especially a paddler. The shaft and wheels are aluminium, for the same reason. Geoff
Reply #35 on:
January 22, 2010, 03:30:02 AM »
It's not the way it looks WHILE you're building it that matters - it's how it looks AFTER you've built it!
Balsa's a great material.
Reply #36 on:
January 22, 2010, 04:00:28 AM »
I have to agree with Stuart, Geoff. Some of the models I've built looked like a right pile of &*$£ while I was building, but with a bit of elbow grease they generally turn out okay.
The advantage with balsa is that its so easy to shape, so you shouldn't have any real problem.
PeeWee
Reply #37 on:
January 22, 2010, 07:29:20 AM »
Progress is progress and its all in the direction of a lovely finished boat
. reminder to self, get in the workshop
R.G.Y.
Reply #38 on:
January 22, 2010, 08:28:51 AM »
I was just worried some modelers might think it was rubbish. Thanks guys. I used the same method for the Glen Usk but with 1/16" sheet, this time I used 1/4"so have a better chance of getting a good shape. Four more strips tomorrow and out with the sanding block. Balsa for the deck is 1/8". Last time I saved the dust from the sanding mixed it with pva and filled the hollows and gaps. geoff
Reply #39 on:
January 22, 2010, 08:36:52 AM »
Geoff, I hope you'll find our members will never slag someone off for trying - We may give advice on better methods or how to improve things, but never ever make comments that would put someone off, at least certainly not intentionally!!
The fact is that you have the basics of a hull, and with some work it can be made into a decent job - Nothing to be ashamed of in that!
If someone else
appears
to do things in a better way, thats' fine, it's something you can make a note of and perhaps aspire to in a future build, but it certainly doesn't mean your methods are any less valid...
And just think of how fit your right arm will get with all the sanding!
Last Edit: January 22, 2010, 10:08:34 AM by Eddy Matthews
Talisman
Reply #40 on:
January 22, 2010, 09:39:41 AM »
Geoff, If it makes you feel any better i have just finished making a plug .... expanding foam first - easy to sand ... a ton of body filler later and an exhausted arm and fed up. Makes me wish i had used Balsa!
I can also see the potential in your hull so keep it up!
steamboatmodel
Reply #41 on:
January 23, 2010, 05:16:01 AM »
The only disadvantage I find with using Balsa is its price, but my wife claims I complain about the price of everything.
R.G.Y.
Reply #42 on:
January 23, 2010, 07:05:19 AM »
Gerald, Have you seen my stock of balsa, photo earlier in this post. Just used a 1/4"+ 4inch + 4ft plank of balsa, still had the price sticker on it 35p!! it is 1970 vintage.
Kim, I have used polyurethane foam for a scale collier. This was covered with cider can plates. Will find a picture to post.
Eddy, My right arm is getting plenty of exercise acquiring the cider cans. Could that be the reason for the rough planking. I don't know how long I have taken but when I split it can it count as two hulls, still not quicker than Stuart.
Finished the planking hurray. Fixed the sponsons ( 3/8 balsa sandwiched between 2 pieces of 1.5mm ply ) Next the magic bit braking it in half tomorrow. Photos of sponsons clamped up,engine - boiler room and 3 models relegated to the workshop. Geoff
Last Edit: January 23, 2010, 07:11:57 AM by R.G.Y.
djcf
Reply #43 on:
January 23, 2010, 11:27:35 PM »
Hi Geoff,
Enjoying reading about your build, keep up the good work. By the way that is some stock of balsa you have!!
steamboatmodel
Reply #44 on:
January 24, 2010, 04:19:00 AM »
"Gerald, Have you seen my stock of balsa, photo earlier in this post. Just used a 1/4"+ 4inch + 4ft plank of balsa, still had the price sticker on it 35p!! it is 1970 vintage."
Yes I did notice your stock, it almost cost me a keyboard, I have horded some balsa myself, but I shudder every time I have to buy more at the hobby shop.
3
4
5
46
DUKE OF DEVONSHIRE
