Author Topic: DUKE OF DEVONSHIRE  (Read 339982 times)
Re: DUKE OF DEVONSHIRE
« Reply #120 on: March 11, 2010, 04:39:24 AM »
Had another look at the gas canister! It was at 60 degrees, through it did look like 45 in the photo. Did a bit of fettling to a frame ( butchered it right out) now the canister is at 85 degrees, so will be OK. Might have to make the steps removable to get to the tap though.  Geoff
« Reply #121 on: March 11, 2010, 05:12:44 PM »
mmmmmmmmm PS's....I can see an isolicies triangle depicted there RGY...but only on the axis of the gas discharge threaded tube..... :c002
But if you increase the base angle to 85 degrees from the horizontal you must exacerbate the potential for  :06 - Derek
« Reply #122 on: March 12, 2010, 03:56:46 AM »
Right thank you Derek. Geoff :angel
« Reply #123 on: March 13, 2010, 04:27:19 AM »
Unfortunately I had sent for the grating kits before mick told me about the fly screen trick. So I have to use them :-[ anyway they look OK. Couldn't cover the entire stern in grating as there has to be a davit there. this was used when beach landing to retrieve the kedge. The black spot on the deck is the posision of the capstan. Still plodding on with the plating. I am using impact adhesive, the trick is let it dry don't be in to much hurry. Have another job going at the same time. If any edges lift I run a little super glue in under and holed it down till stuck. Geoff
« Last Edit: March 13, 2010, 04:37:06 AM by R.G.Y. »
Offline PeeWee
« Reply #124 on: March 13, 2010, 05:37:01 AM »
nice use of the empties,  a good excuse to the better half.  "Sorry Honey i have to drink for the free model plating."   :whistle
« Reply #125 on: March 13, 2010, 05:57:04 AM »
... If Carlsberg did paddlers
Comming together Geoff, wooden gratings do look more realistic and nicely done.
Cheers,
I'll get my coat ...  ;D
« Reply #126 on: March 13, 2010, 08:28:24 AM »
Flushed with the success of the gratings. I am contemplating constructing the bridge deck and walkway around the funnel with them. Just like on SS Great Britain. This can't be seen from photos I have. But I think it will be in character. As Duke is a very old fashioned design. Even for 1896. Geoff
« Reply #127 on: March 13, 2010, 09:02:47 AM »
I am looking for stanchions at 35mm high 1,2,3, hole no problem 3 hole plus handrail no joy. anyone help? Geoff
« Reply #128 on: March 13, 2010, 09:08:57 AM »
Yup, no problem.... James Lane...
JAMES LANE (Display Models)
30 Broadway
Blyth
Northumberland
NE24 2PP
I don't have a phone number handy, sorry....
« Reply #129 on: March 13, 2010, 09:25:16 AM »
James Lane telephone number:  01670-352051
« Last Edit: March 14, 2010, 01:51:52 AM by Eddy Matthews »
« Reply #130 on: March 14, 2010, 01:50:20 AM »
Thank you Eddy. I did have this number and had rung it a few times over the last week, but was unable to get a response. However I have just placed my order. Geoff
« Reply #131 on: March 15, 2010, 09:45:57 PM »
The cost of this boat is getting out of control.  £119 for the boiler, £20 engine, £5 balsa, £16.50 grating, £36.50 stanchions, £15 glue. Beer, cider and larger £70. Total so far £282.
No construction for a time.
Sailed Glen Usk yesterday, last sail 9 months ago. Couldn't get steam up, so I thought then the safety valve blow. The pressure gauge wasn't working! apart from that a good day.
« Reply #132 on: March 16, 2010, 04:30:12 PM »
Hi D's....goodness RGY...only £70 for  Beer, cider and larger... :a102  you must be near tea-total  :06 .....Derek
« Reply #133 on: March 16, 2010, 08:13:17 PM »
Yes and the wife drank most of that  :'(Geoff
« Reply #134 on: March 17, 2010, 08:47:55 AM »
Derek this is the only model use I found for whiskey  ;D bottles.  geoff
