Author Topic: Building a river boat  (Read 97987 times)
Re: Building a river boat
« Reply #90 on: October 05, 2015, 11:34:56 AM »
Yes 31c today 30c tomorrow the it cools for the rest of the week.
Offline victor vector
« Reply #91 on: October 11, 2015, 03:30:43 PM »
The external door to the rear deck is almost complete.
Same construction as the windows , 3 laminations of 18 x 100 mm ( 3/4 x 4 inch ) hardwood epoxy glued together .
Marine plywood infill panel.
Hanging the recycled hardwood front door .
The pump-out and flush pipes coming up through the front deck.
2 x 6 treated pine screwed though 2 x 2 wall framing and hardwood decking with six and four inch batten screws ,and epoxy glued to keep pipes rigid and reduce stress to cemented pipe joints.Pipes were fitted in with a wooden block and hammer .There is a treated pine backing block screwed under the decking.
« Last Edit: October 18, 2015, 09:18:39 PM by victor vector »
« Reply #92 on: October 19, 2015, 03:45:24 PM »
Camlock pump out fitting.
Bottom to top :
50 mm DWV joiner.
50 > 40 mm reducer.
40mm threaded adaptor.
Camlock fitting.
Camlock fitting plug.
« Reply #93 on: October 19, 2015, 05:04:17 PM »
Coming together  :clap  :bravo: clap  :bravo
« Reply #94 on: October 19, 2015, 05:30:35 PM »
Hullo PD's.....& always watching on Victor  :kewlpics......and robust construction in all areas   :bravo
However I must ask why you are using Master Foods Brand TOMATO sauce as glue  :tongue1
Keep up the good work & images......... Derek  :beer
« Reply #95 on: October 19, 2015, 06:12:12 PM »
Hi everyone .
Derek ,about  those sauce bottles .....
I just found it too tiring to squeeze that glue out of that 20 liter bucket. :weight
« Reply #96 on: October 19, 2015, 06:44:07 PM »
Well that's OK Victor  :whistle...
I understand that the Titebond III is a brilliant glue  :towel   .....however having worked professionally with Lloyds and Det Norske Veritas in marine survey work, best destroy the images of Tomato sauce glue bottles .... Derek
« Reply #97 on: October 19, 2015, 09:53:17 PM »
Yes Derek , I`m very pleased with the Titebond`s  performance .
The entire outside walls are covered with canvas set in the Titebond glue .
All 40 liters of it !
Nothing seems to touch the surface at all , from below freezing cold through 40 C heatwaves , relentless sun and occasional rain.
It still looks like the day I first made the wall panels.
Your days at Lloyds and Veritas sound interesting , and working in survey , you have probably picked up numerous mistakes I have made , that I`m not even aware of .Still , I`m doing my best to do a reasonable job given my limited budget  , but if I really mess up with something , feel free to kick my butt ..... :nono
« Last Edit: October 20, 2015, 11:28:51 AM by victor vector »
« Reply #98 on: October 25, 2015, 04:57:34 AM »
Modified front door .
A hardwood stile was inserted at window height , and a rebate cut to accept the lower canvas covered plywood infill panel and glazing above.
Inside view.
« Last Edit: October 25, 2015, 01:50:26 PM by victor vector »
« Reply #99 on: October 25, 2015, 08:18:20 AM »
Lightweight metal covers for the pipework.
Top plywood cover will hinge for access to camlock fittings.
« Reply #100 on: October 25, 2015, 10:42:04 AM »
 :bravo :bravo :no1b :clap :clap
« Reply #101 on: October 25, 2015, 02:22:36 PM »
Thank you Damien .
I`m hoping when all is painted that the covers will not look too awkward and bulky.
If all else fails I shall resort to the old " put a pot plant on top and soften the look " trick ........ ;)
« Reply #102 on: October 27, 2015, 07:58:46 PM »
Insulating and fitting the eaves over the foredeck.
Some weird angles on those trim pieces.
I`m pulling the gutters apart and sealing the joiners with gutter sealant.
Manufacturer claims that they are water tight when just pushed together .
I tapped them together with a wooden block and hammer , making sure that they were fully seated .......you can guess the rest ?
Anyway , this should fix it.
« Last Edit: October 28, 2015, 05:37:57 PM by victor vector »
« Reply #103 on: October 29, 2015, 07:46:34 PM »
« Reply #104 on: November 08, 2015, 10:22:00 AM »
Making the mandatory steel guards for the front of the waste water tank.
Setting out.
50 x 50 x 5 mm ( 2 x 2 x 3/16 ) mild steel angle welded together.
« Last Edit: November 17, 2015, 03:45:40 PM by victor vector »
