Author Topic: Building a river boat  (Read 97991 times)
Re: Building a river boat
« Reply #105 on: November 08, 2015, 11:35:18 AM »
 :clap :clap
Offline victor vector
« Reply #106 on: November 17, 2015, 03:49:23 PM »
I have started glazing the windows .
The photo shows seven panes fitted along the side of the cabin.
Because of it`s optical clarity , cast acrylic Plexiglass is said to be virtually " invisible " to UV rays .
I used the original german made Plexiglas , it comes with a 30 year non - yellowing guarantee .
Care will be required when cleaning these to prevent scratching.
Plexiglas will represent a 50% weight saving over float glass and will be more flexible .
If the pontoons are pushed onto an uneven bank flex could be an issue.
Plexiglas has 10 X the impact resistance of float glass at 4.5 mm thickness.
Glazing is set into the rebates with butyl mastic , a soft sealant that skins over and is paintable .
It is  used for sealing things on  caravans and mobile homes.
« Last Edit: November 18, 2015, 06:30:41 AM by victor vector »
« Reply #107 on: December 09, 2015, 08:11:44 PM »
Hello Everyone ,
I`m getting into hot water.
I have decided to use a 240 V hot water heater when connected to shore power to save lugging so many gas bottles aboard.This unit is very small and compact at 25 lts ( 6.6 US Gallons ).It will fit neatly under the kitchen bench and not take up much space.
25 lts is not really sufficient for showering for two people , so this little heater`s function is to boost the temperature of some pre heated solar hot water stored up on the shantyboat`s roof.
The pre heater will contain 100 lts ( 26.5 US Gallons ) of hot water that will be plumbed into the cold water inlet of the little water heater.
This is all experimental at this stage , but so far it looks promising.
In principal it`s all very simple , here is illustration of a similar pre heater .
These are batch heaters , meaning that the storage and solar collector are combined as one simple unit.
The main advantage is simplicity and some protection from frost ( batch heater volume ).
I anticipate having to provide an insulated cover to protect the pvc pipes from very cold nights frost ( rare here ) , but more importantly , since solar is
a " uncontrolled " energy source , to prevent the collector pipes from over heating on very hot days.
Small electric boost water heater .25 ltrs , ( 6.6 Us Gallons )
This is a photo of building the solar collector tray. 2 inch foam insulation sandwiched between 1/4 in plywood , reflective foil lining reflects sun`s radiation back towards the back of the black collector tubes..
The collector on the left will drop into the box as a complete unit once the box is installed on the roof.
http://i.imgur.com/A9G5aya.jpg
3/4 inch plywood pieces retain the collector tubes.
Paint is mat black high temp epoxy.
For initial testing , I just filled one black pipe at 8 :30 am ( ambient temp 25 C or 77 F)
4 hours later the water in that four inch pipe was too hot to put your hand into.and would have required tempering down with cold water.
I will require some insulated covers to prevent overheating on really hot days , such as we have just experienced here earlier this week.
That will require some input from me on really hot days to close the covers after heating up the collector , but it`s not a big chore is it really ?
I will need to install some digital temp probes at the collector so that I have some idea of just how hot things are getting in there , but it will just become part of a daily routine of life aboard in summer .
« Reply #108 on: December 09, 2015, 08:56:52 PM »
 :clap :bravo :bravo :clap :bravo :clap :bravo
« Reply #109 on: December 09, 2015, 09:30:07 PM »
Hullo Victor.......with each posting we continue to see 'good' technology being built in & utilised.......
This is opposed to 'useless' mod cons......... Derek
« Reply #110 on: December 10, 2015, 12:24:26 AM »
Thank you for the kind words and interest , gentlemen.
« Reply #111 on: December 10, 2015, 08:32:40 AM »
Victor.....with the amount of stored water at elevated temperatures you may wish to consider some low voltage [12 or 24V] ionic protection
I am pretty sure it is a variation on salt water chlorinators for swimming pools.............relies in the minerals [in the equivalent] of domestic tap water & thus the impressed current kills natural bacteria that would send tap water rancid at the elevated temperatures  :41
This would seem preferable over the chemical tablets :nono  that the 4x4 off road people use to maintain the quality of their stored water
« Reply #112 on: December 11, 2015, 11:46:27 AM »
Hello Derek
Thank you for the comments .
You are absolutely right of course.
I have a friend here that does exactly that and it is deceptively simple to set up.
He treats river water with a small 12 volt charge  and it transforms his murky brown river water to sparkling clear in 24 hours.
It kills virtually all  bacteria and pathogens .He actually drinks that water , and has done so for years .
Personally, I would not , but would not hesitate to use it for ablutions.
I`m having some real bandwidth issues here at the moment , ( school holidays )  so I may not reply promptly at times ,I can only get  wi-fi  where i am , and it`s very prone to drop outs and
at times I cannot even get a connection.
Thanks again for the advice ,you are  spot on !
« Reply #113 on: December 16, 2015, 01:08:47 PM »
I was hoping to complete my solar collector in the next day or two ......
The weather forecast says otherwise :
Today :            40.0 C  ( 104.0  F )
Tomorrow:       42.5 C  ( 108.0  F )
Friday :            41.0 C  (  105.8 F )
Saturday :       43.3 C   (109.4 F )
Too much for me ......... :(
I did manage to complete some work on the rear deck access door before the heat hit .
« Last Edit: December 17, 2015, 03:07:26 PM by victor vector »
Offline Roderick Smith
« Reply #114 on: December 20, 2015, 04:26:46 PM »
I whisked through Mannum earlier in the week, collecting my boat from Greenings and heading to the Glenelg.  I knew that I wouldn't have time for a personal inspection, and so didn't ask for a location.  The coming year is a bit quiet for planned downriver events, but there will be ones in Echuca for PS Adelaide's 150th, plus Wentworth Junction Rally (July) plus possibly a rally with the club based at Renmark.
Roderick
« Reply #115 on: December 20, 2015, 09:08:23 PM »
Merry Christmas to all ,
Thank you for your interest , ( or boredom ) this year.
 See you next year , best wishes
Victor V
« Reply #116 on: January 06, 2016, 09:56:43 AM »
Happy new year everyone !
I have started work on the water tank that will store river water to supply the shower and hand basin in the bathroom.
My water tank for stored river water is a cut down 200 liter pickle barrel.
A 18 mm ( 3/4 inch ) marine plywood ring is placed inside the top of the barrel to restore rigidity .
It will be epoxy coated to render it water proof , then painted.
Top inlet.
Manual fill pump fixed to the wall.
This is untreated river water .It contains a lot of colloidal clay.
The easiest way to separate the clay deposits is to add a tea spoon of alum.
The staff inside the barrel has markings spaced at 150 mm ( six inch ) intervals.
This is the water after four hours .
Eight hours after adding the teaspoon of alum the water is clear.
The silt deposit seen at the bottom is drained off after each use.
« Last Edit: January 26, 2016, 11:38:26 PM by victor vector »
« Reply #117 on: January 06, 2016, 11:29:52 AM »
10 / 10 for ingenuity Victor.   :clap :clap :clap :clap :clap
« Reply #118 on: January 11, 2016, 12:10:36 PM »
Wood stove heat shield is fitted.
I cut the brackets from scrap metal roofing.
Flat sheet metal gussets fixed to the back of the panel.
Alum. channel fitted to edges.
Paint still required.
« Reply #119 on: January 11, 2016, 12:45:15 PM »
A question for someone who may know .......
How do you people think I would go painting this with normal acrylic paint ?
The four inch flue has just over 100 mm ( four inch ) clearance to the panel .
« Last Edit: January 11, 2016, 12:53:54 PM by victor vector »
