DUKE OF DEVONSHIRE
18
19
20
21
46
Topic: DUKE OF DEVONSHIRE (Read 340275 times)
PeeWee
Re: DUKE OF DEVONSHIRE
Reply #270 on:
July 21, 2010, 01:27:08 AM »
that's a good trick, will have to add it to all the rest you and others have provided here.
Talisman
Reply #271 on:
July 21, 2010, 07:21:33 AM »
Geoff, I do like that idea... she really is taking shape.
R.G.Y.
Reply #272 on:
July 24, 2010, 06:09:31 AM »
Started a job I dislike the rails.
This is my method, first I drill the holes for the stanchions. Then bend a wire to fit the holes. I then duplicate the wire as many times as required. Threading the stanchions onto the top wire and into there positions, followed by the lower wires. Next place the base plates on the bottom to hold the split together. Place all in position in the holes, straiten and carefully dab super glue on the joints. Remove paint and replace. Any one know a better way there must be.
In the final photo I have added the kicking boards and canvas dodgers. The dodgers made from cooking foil . Geoff
Reply #273 on:
July 24, 2010, 06:15:22 AM »
I would never have thought of using cooking foil for the dodgers Geoff. I have to say it looks surprisingly realistic!
PeeWee
Reply #274 on:
July 24, 2010, 04:26:16 PM »
Nice looking rails.
the way i do mine is completely off model. i draw an outline on a board and drill the holes according to where they will be on the boat. cut the wire to length and glue the stanchion's in. then i bend the wire and stanchion's as one.
the other option i sometimes use is to glue the starting stantion and all the wires on and then add on stanchion at a time gluing and bending as i go. i find this works well for me on tight multiple bends.
As they say, no one way is right or wrong. just what works for the individual.
R.G.Y.
Reply #275 on:
July 25, 2010, 06:11:50 AM »
Thanks Ian I will try this next time. Geoff
Last Edit: July 25, 2010, 06:14:01 AM by Eddy Matthews
R.G.Y.
Reply #276 on:
July 29, 2010, 06:04:51 AM »
One problem with your method Ian, the stairs? But I do like the life belt holders.
More photos to check the alignment of the stanchions and rails. A few minor adjustments required, then they can be fixed. Hand rails added and boarding gates made. Also note hand rails for crew around the sponson.
close up of lifeboat cradles. Geoff
Last Edit: July 29, 2010, 06:09:28 AM by R.G.Y.
PeeWee
Reply #277 on:
July 29, 2010, 06:44:59 AM »
Stanchions looking good. I have to admit that i have never thought about stairs, believe it of not i have never made a model with them only ladders where the top rail is left long to accommodate. i hope this did not cause too many problems.
R.G.Y.
Reply #278 on:
July 29, 2010, 07:01:12 AM »
Not at all Ian,
well no more than usual.
Geoff
R.G.Y.
Reply #279 on:
July 31, 2010, 01:11:19 AM »
Back to the chair legs for the handrail.
I have sawn up all the straght pieces for firewood. So have to cut up the bent legs.
Geoff
R.G.Y.
Reply #280 on:
August 03, 2010, 07:08:12 AM »
Handrails going on, starting from the middle so only fitting one end at a time. I mark the position of the holes by wetting my finger and wiping it on the top of the stanchions, placing the rail in position will show a wet spot when removed. Marking the obtuse miters by marking each side of the next rail then join the marks. Geoff
Reply #281 on:
August 03, 2010, 07:23:40 AM »
Thanks for the update Geoff, it's been s quiet on here over the last few days that I was beginning to wonder if anyone else was still alive!!
Looking good so far.....
R.G.Y.
Reply #282 on:
August 05, 2010, 04:16:41 AM »
EDDY, I think every one in UK IS ON HOLIDAY IN DEVON.
I have managed to complete all of the wooden blocks. With out steping on any more.
Forward davit strung. Geoff
Last Edit: August 05, 2010, 04:19:51 AM by R.G.Y.
R.G.Y.
Reply #283 on:
August 05, 2010, 07:53:28 AM »
Finished the handrails. Just the gates to do now. Two will open with a bit of luck. Geoff
djcf
Reply #284 on:
August 05, 2010, 07:43:10 PM »
Hi Geoff,
Looking really good
Hull painting time coming up now?
18
19
20
21
46
DUKE OF DEVONSHIRE
