Author Topic: Paddle Steamer Ryde  (Read 4911 times)
Offline edmundfaulkes
Paddle Steamer Ryde
« on: June 24, 2016, 07:54:40 PM »
Some time ago I posted some photographs of a model I had constructed from scratch of the Paddle Steamer Ryde - The original Denny Bros of Dumbarton built, now languishing sadly in Binny Marina on the Isle of Wight.
I've been experimenting with videoing models with a GoPro type camera, mounted on another paddle steamer of mine.  Here is the result - on a nice sunny if slightly windy day in Dundee.  Clink on the link to see the video:
https://www.youtube.com/watch?v=Slh9JI-16Xc
Enjoy!
« Last Edit: June 25, 2016, 12:06:34 AM by edmundfaulkes »
Re: Padlle Steamer Ryde
« Reply #1 on: June 24, 2016, 08:22:17 PM »
.....and a fine bit of footage Edmund. :kewlpics......
We could clearly see the effects of windage....just after the first minute with the Port paddle box awash, then moments later still water...........
Thanks for sharing........ Derek :beer
Re: Paddle Steamer Ryde
« Reply #2 on: June 24, 2016, 09:34:26 PM »
Thanks!
It was quite a gusty day.  I used to use a keel with weight below but now am using internal ballast as there is too much weed in the pond
Offline Mercury
  • Gold Subscriber
« Reply #3 on: September 10, 2016, 10:13:03 PM »
Model looks great Edmund.
Did you make your own wheels or use modified Graupners?
« Reply #4 on: September 10, 2016, 10:25:57 PM »
Ryde has rather small wheels,12cm diameter with a blade width of 5 cm. I have used a modified set of wheels from Float a Boat in Australia, modified in that I have extended the blades. Still not satisfied with them however and I am in the process of building my own. Speed leaves a little to be desired with such small wheels. I have another similar sized paddle stranger the Cardiff queen which has Graupner wheels and she's quite a goer!
