Author Topic: Steam Engine For Mountfleet St. Nectan  (Read 13877 times)
Offline ir3
« on: December 07, 2010, 11:21:37 AM »
What engine would be suggested for the Mountfleet St. Nectan. The boat would displace about 45 lbs and is about 66 inches long. A Stuart Twin Launch was recommended with a Maccsteam 5" boiler. Sounds great but I am not a machinist and the Twin Launch is available only as unmachined castings from Sturat. Any other suggestions would be appreciated.
As an aside, I have a complete set of the Mantua 1:200 Titanic kits that I would consider a trade for a suitable steam engine. I am in the USA so postage is always a consideration but there are ways to ship and keep the costs down.
Thanks,
Iran Ausley
Re: Steam Engine For Mountfleet St. Nectan
« Reply #1 on: December 07, 2010, 04:06:40 PM »
Hi PD's......& welcome Iran ...... :coffee
A 2000 mm model vessel is not a small thing to steam power ....... :sobbing
Both the Japanese Saito & the French JMC publish nominal hull proportions relative to their engines...it is probably a good way to start & consider your options
Here is the Saito listing.....you will find a similar listing for JMC via GOOGLE ...both of these manufacturers have respected names in the model steam industry....keep us posted with your thoughts.....Derek
PS.... I also have a JMC3H = 3CC &  Saito Y2DR = 9CC
« Last Edit: December 07, 2010, 09:23:08 PM by derekwarner_decoy »
« Reply #2 on: December 07, 2010, 09:16:07 PM »
Hello again Iran,
PM sent regarding your mail to me about my build of the St Nectan. Sorry about the lack of information on steam engines as my version was powered by electric motor, and I've never tried a steam powered craft.
As another PS to your letter above, I too am building the Titanic and could have wished I knew about your offer earlier.  :darn
It's an expensive boat to build eh !!
All the best with your research
Ken
Offline ir3
« Reply #3 on: December 09, 2010, 11:11:13 AM »
Thanks for the replies. I guess the question is, of the ready built engines such as the T3DR or the Double D10 or perhaps others which would be the best to reasonably propel a boat of that size. As far as space is concerned, there will be plenty of room for a water tank, large fuel tank, large boiler, etc. The only question is how much power is needed and will any of the available engines to the job.
Thanks in advance,
Iran
« Reply #4 on: December 09, 2010, 08:51:21 PM »
A great looking boat as large as this deserves an engine that not only does the job but looks the part too. Having used a PM Research V twin I think it would do the job but an inline vertical twin would look much more realistic. We have available here in New Zealand a kitset inline double acting twin cylinder engine of 20mm bore by 20mm  stroke but you would need to find someone to machine the kit. Regards, Ian.
Offline ir3
« Reply #5 on: December 10, 2010, 11:28:14 AM »
I wish I had the machinists skills, I would love to be able to build steam engines from castings. I think I have settled on an engine for the St. Nectan. I am considering the Saito T2GR. It is quite powerful and is advertised to be used in boats of 1.2 to 3 meters. I will probably match it with a Maccsteam 5 or 6 inch boiler. One attribute of the St. Nectan is there is a lot of room for the workings.
Thanks once again,
Iran
« Reply #6 on: December 10, 2010, 05:02:12 PM »
Hi PD's....Iran...I have had no dealings with MacSteam...but from all posted reports both here & @ ModelMayhem....Mike from MacSteam [the owner] is very helpful & good to deal with
It may well be worth your time in discussing your intended engine with Mike to gauge his thoughts as the Saito T2GR will consume  :crash quite a volume of steam....Derek  :beer
BTW....differing WEB sites for Saito resellers have quite a few TYPOS in their Saito engine specification listings  :ranting
One WEB page lists the Saito T2GR as 5.4 cc....another 25 cc  :a102
Offline ir3
« Reply #7 on: December 11, 2010, 04:59:37 AM »
Thanks Derek,
Saito,  shows it as a 20mm bore and 20mm stroke and I have to assume they are correct on the size but their displacement calculation is probably off. It could account for the fact that this engine is a lot more expensive that the T2DR which has a 12mm bore and 12mm stroke. It's good that you brought that to my attention. I will continue to research this engine and I will check in with Mike at Maccsteam to discuss boiler selection. Will post my results.
Iran
« Reply #8 on: December 11, 2010, 02:45:13 PM »
mmmmmmmm PD's.... :nono something so simple can easily be mis-understood or mis-represented
From my school days.... :angel ...volume of a cylinder was ...[I hope they haven't changed after 50 years  :spam]
Pi x radius squared x height :azn: simple OK? - .....  :shhh so now we introduce
1. what is the actual swept volume?
2. do the technical specifications consider the double acting functionality?
3. do the technical specifications consider the return stroke volume is MINUS the rod diameter?  :whistle ...Derek
Offline ir3
« Reply #9 on: December 12, 2010, 04:35:28 AM »
The Saito spec only says it is double acting, bore 20mm, stroke 20mm. Doing the math, it is about 6.3cc per cylinder. I am not sure what double acting actually means. If Saito is correct about the bore and stroke, the total swept volume is 12.6cc for the two cylinders combined. I assume since it is double acting the displacement is 25cc which seems about right.
I made contact with Mike at Maccsteam and it appears that the 6" boiler will do the job very nicely. Running time 20 - 30 minutes. Maybe a little overkill but better to have more running time than not. The boiler is 9" high which is quite large but I assume that I can put the stack of the boiler under the stack of the model. I don't want to unpack the kit as of yet to make a measurement.  Hopefully, someone who has built the St. Nectan can advise me on this.
Thanks once again,
Iran
« Reply #10 on: December 12, 2010, 09:16:02 AM »
..... I am not sure what double acting actually means. .....
steam pushes the piston forward, then pushes it back again as opposed to steam pushes the piston forward, flywheel brings it back - as in 'MAMOD' (for example) steam engines
Offline ir3
« Reply #11 on: December 13, 2010, 04:10:40 PM »
Hi PD's,
It looks like either the Stuart Double 10 or the Saito T2GR. From the vast experience of the PD's which would be preferable. There is an opportunity for a Stuart Double 10 at auction. It is used but has the reversing gear and gearbox so it is inviting. A quick opinion on the choice between the two would be great.
Thanks,
Iran
« Reply #12 on: December 13, 2010, 04:39:49 PM »
Hi PD's......Iran  :shoot ...you ask the impossible from us
If the Double 10 was well built & 1/2 the cost of the other engine it would appear to be a   :gift buy
If the double 10 was 1/2 the cost of the other engine ...but turned out to be a well worn out & poorly machined engine  :ranting :a102 ...your spent funds may need additional units for you to have the engine repaired :hammer   :hammer by a competent model engine re-builder
Some 5 years ago I purchased on eBay a 20x20 oscillator completed with Maudsley reversing gear ....it is the greatest heap of junk I have ever purchased......... :c002
It too can be a retirement project for me ....but the reversing gear will go
I would never again purchase a second hand component of this nature without first knowing the actual quality & the manufacturer.......Derek
Offline ir3
« Reply #13 on: December 14, 2010, 02:22:18 AM »
Thanks Derek,
Well said. No problem bidding on an item the I know that I can deal with if there are problems but not the steam engine. No expertise whatsoever. At least the Saito will be new, and have been tested at the factory so I am at least that much further ahead.
Iran
« Reply #14 on: December 15, 2010, 09:06:03 PM »
Hi PD's......Iran....here is a French model engineer selling refurbished Stuart D10 engines for  € 1,300 ...does this slot into your expectations?....... :whistle ....Derek  :beer
____________________________________________________________________________________________________
Si vous recherchez ou vendez des matériels neufs ou d'occasion relatifs au modélisme vapeur, me contacter et me préciser leurs description, prix et comment vous joindre.
If you are looking for or sell new or used equipments relating to your steam hobby, contact me and tell me their description, and your asking price! I will try to meet your expectation.
Je vends / I sell :
•1- Je vends 3 moteurs Stuart D10 neufs avec inversion par coulisses de Stephenson, prix unitaire hors frais de port 1 300 € / I sell three new Stuart D10 engines with slides inversion Stephenson, unit price excluding postage € 1,300 - Me contacter directement/ Contact me directly.
