Author Topic: Long build.. Talisman 1  (Read 62032 times)
Re: Long build.. Talisman 1
« Reply #30 on: March 25, 2009, 09:16:11 AM »
Kim,
I have to admit that I'm almost as excited as you about this model.... it's way bigger than anything I would attempt, but fascinating all the same!
Can I ask where you got your 1:24 railings and stairs etc from? I have an idea for another project where they could be useful!
« Reply #31 on: March 25, 2009, 09:31:51 AM »
hi, i used this site as they had all i needed in stock. 1:24 and smaller scales seem to be more popular with dolls house builders. never thought id see the day when looking at dols house stuff would keep me amused for hours  ;D
http://www.mollys-house.co.uk/
http://mollyshouse.wahmworld.com/store/
« Last Edit: March 25, 2009, 09:38:01 AM by Talisman »
« Reply #32 on: March 25, 2009, 09:46:18 AM »
I do like some of these carts they would look great loaded with luggage on deck but a bit expensive.
http://www.phoenixmodeldevelopments.com/acatalog/Carts_and_Barrows_1_24.html
« Reply #33 on: March 26, 2009, 06:56:20 AM »
Some bits came through the door today.
I could be converted to work 1:24 the detail at this scale is good.
(Next project is going to be Denny's S.S. Sir Walter Scot at 1:24 - which gives a hull length of approx 42 inch )
First thing to arrive was some unpainted figures from a shop in China. Being sceptical about the standard of figures i ordered the min quantity i could expecting them to be of poor quality.
I was surprised for less than £7.00 delivered from china i received 24 assorted figures (inc 3 types Children). The quality is spot on and they are definitely of the prieser variety.
The only problem i have with them is some of them are a wee bit modern looking and will need some modification to fit in with the 1900 fashion. No ladies jump suits back then were there ? :)
Next up was stairs banister and newel posts. the stairs are a wee bit ruff / fluffy as they have been cut from MDF. Not to worry they will be covered with veneer and brass edging, stained and should come out looking good with a bit of effort.
A couple of pics of 1:24 people from China against 1:48 preiser people.
« Reply #34 on: April 24, 2009, 04:17:02 AM »
Ok, now it starts to get interesting....
Today i collected the hull and brought it home complete with approx 25 years worth of dust and spiders web's. The wife allowed a brief stop on the dinning table for a hoover and a couple of pics before it was ordered to the bench.
I think I'm allowed to say this as it is not my handy work but it does look good to me.
I can only imagine that worked stopped on the boat as it is 14kg (2.2 stone) in its present form and a lot of work still to go.
This evening's plan is to start comparing the plans to the hull and make a plan of attack..
So far i have had little joy trying to get a company to laser cut the wheels for me one company has been messing me around for a month ... the battle continues
Hopefully not be to long before serious building gets underway, watch this space.....
« Last Edit: April 24, 2009, 04:19:14 AM by Talisman »
« Reply #35 on: April 24, 2009, 04:20:36 AM »
Just for ref the 1:48 maid is the same size as the full sponson :)
« Reply #36 on: April 24, 2009, 05:05:58 AM »
My god that's BIG Kim, but I bet it will look fantastic on the water!!
« Reply #37 on: April 25, 2009, 05:29:23 AM »
This eve i had a play on the lathe. I say play as i have had no formal training and every project is a learn by discovery affair.
I made an insert for my pulley which Eddy supplied me with. it looks great and i was dead chuffed with myself until i found it is very slightly off centre  :-\
So a trawl of the internet and i came up with this site.
http://www.motionco.co.uk/
A phone call to be made on Monday.
Now looking for some help / information
I really have been struggling to find a company to make my paddlewheels or at least the rims and floats.
I have produced the drawings in .dfx which i believe is what they need.
My problem is that despite making payment a month on and the company still cannot do the work. I'm at my wits end with them and now need to find a new supplier... :squareone
So, can anyone recommend a company who would be prepared to do this work for me, anyone you have used or recommend?
Thanks in advance
« Last Edit: April 25, 2009, 05:32:39 AM by Talisman »
« Reply #38 on: April 25, 2009, 05:41:44 AM »
A friend of mine is running one of these motors/pulleys in a large paddletug Kim - He made an insert just using a pillar drill and hand tools, so it's way off centre!! Not just a little bit, but maybe as much as 1/8"
Surprisingly, it still works perfectly - With the belt very slack to allow for the movement. He's never had the belt jump or come off..... it doesn't look very pretty, but it does work!
« Reply #39 on: April 25, 2009, 07:22:02 AM »
Hi Eddy, after doing the costing on running gear i think a little 'wobble' in the system might have to be acceptable. I have to say im not quite 1/8th out which for my low level of skill is quite an achievement.
« Reply #40 on: April 28, 2009, 08:25:52 PM »
Blimey,i have just had a quote in to laser cut the rims, banjo wheel and paddle floats- to supply the material and cut i have been quoted £264.00  :o
Now where did i put my hacksaw and files...
« Reply #41 on: April 29, 2009, 08:28:46 AM »
A bit of work done ...
Bow and stern decks scibed lined and varnished.
Bushes cut for drive shaft and rudder.
Rudder assembled and roughly shaped.
Steering bracket fashioned from a spare Mecano sprocket.
Stern windows cut (not convinced this is right will need to do a wee bit more reaserch before putting them on - did she have windows at the stern??? )
Motor molded in silicone for the motor mount.
Doesn't seem much to show given the amount of time it has taken. Like i say its going to be a long build
Found a great shot of the Kenilworth, why do these pics fetch such a high price ???
http://cgi.ebay.co.uk/SCOTTISH-PADDLE-STEAMER-KENILWORTH-MINESWEEPER_W0QQitemZ370193512452QQcmdZViewItemQQptZUK_Collectables_Nautical?hash=item370193512452&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A7%7C39%3A1%7C240%3A1318
« Reply #42 on: April 29, 2009, 08:41:14 AM »
It is amazing how some bits seem to take forever to do isn't it?
But progress has been made Kim, so that's always good! :)
I can see a race coming.... Sir William Wallace and Talisman, which will hit the water first, and which will be completed first? Who wants to run a book on them?
« Reply #43 on: April 29, 2009, 09:02:18 PM »
No race Eddy just a deadline of September.if someone is taking bets i'll stick 2p on Eddy being first...
I would love to come down to the paddler day and to bring this old lady and Jupiter, would really make the journey worthwhile....
< runs back to the bench :)
« Reply #44 on: April 30, 2009, 02:16:12 AM »
hehehehe only kidding about the race Kim - In fact my plans have been delayed a little, so you can get a head start on me.....
I was hoping to get my hull back today, but it isn't ready yet so it will be sunday....
