Author Topic: Steam Fittings  (Read 17853 times)
crash93
Steam Fittings
« on: March 05, 2008, 12:32:11 PM »
Has anybody come across or bought any of these products I was looking at the glass oilers, they look very well made as do all there fittings and a lot cheaper than I thought they would be .
anybody know of a UK supplier
Peter
http://translate.google.com/translate?hl=en&langpair=de|en&u=http://www.modellbau-niggel.de/&prev=/translate_s%3Fhl%3Den%26q%3Dhttp://www.modellbau-niggel.de/%26sl%3Den%26tl%3Dde
Re: Steam Fittings
« Reply #1 on: March 05, 2008, 04:27:14 PM »
Hi Pd's......Crash93..[Peter].. this www.modellbau-niggel.de "Verdrangugsolver" @ EURO 28 seems amazing & the translation suggests that it is a displacement lubricator......the only difficuility in understanding is the porting........
The 400.110 appears to be of conventional construction.......however the 400.112 = bottom ported   :shoot
Another point is ...JMC market a Grassier transparent displacement lubricator to EURO 91.40 & EURO 122.00
I must acknowledge the balance of components @ www.modellbau-niggel.de appear excellent quality and a very reasonable costings
For EURO 28 it must be worth e-mailing them for confirmation of functionality......as the visual aspect of a glass pressure lubricator is great.....check out the opening page from JMC & view the three levels of OIL>>>>>OIL+water mix+ waste water........
 :goodnews..... so please keep us posted
..following is a translation from www.modellbau-niggel.de
Displacement oiler larva OF brass and blasted hargeloetet Oiler into the additional steam pipe to the machine built Oiler into the additional steam pipe fitted ton the machine oil filler plug seals with cone and O-ring starting from oil filler plug seals with cones and O-ring reading off screw for cleaning reading off screw for cleaning glaszylinder from bulkhead Duranglas beidsetig melted on Glass cylinders from bulkhead Glass Duran is beidsetig glaszylinder reciprocally with O-ring sealed Glass cylinders on both sides, with O-ring sealed staybolt and nuts/mothers made of stainless high-grade steel Studs and groove from stainless steel for the adjustment of the quantity of oil can the drilling for oil Ø 0.7mm be drilled out tons adjust the quantity OF oil CAN drilling for oil dia. meter of 0.7mm drilled out Data DATA reciprocally screw connections with cone soldering nipple for 4mm pipe cone soldering nipple sided with fittings for pipe 4mm diameter: 16 mm of glaszylinder visibly 31 mm dia. meters: 16 mm glass more cylinder visible 31 mm height: 68 mm of Height: 68 mm broad: 21 mm of Width: 21 mm of length: 49 mm of length: 49 mm Compression test with 6 bar of Pressure testing with 6 bar
« Last Edit: March 05, 2008, 04:42:42 PM by derekwarner_decoy »
Re: Steam Fittings
« Reply #2 on: March 07, 2008, 07:09:28 PM »
Hi PD's...couldn't resist the temptation  :whistle..so have e-mailed modellbau-niggel.de as below....
Winfried - von Derek Warner in Australien Grüße - ich bin ein Mitglied der Paddel-Enten NETZ Gruppe für vorbildliche Paddel Wheelers [ 1000 Mitglieder weltweit ] u. fand Ihre Web site recenltly bekanntgegeben durch eine von unserem Mitglieder Ich habe 1 errichtet: 24 Skala 1878 errichtetes paddler u. haben eine französische [ JMC ] horizontale Maschine, ein schottisches System des Dampfkessels [ ACS ] u. eines französischen [ Anton ] gaz Reglers - ich umgebe einen Schnäpper Jedoch bin ich an Ihrem.......Verdraengungsoeler-mit-Glaszylinder-400-110 am interessiertesten [ Versetzung Fettspritze mit Glaszylinderschlauch ] Frage - würden Sie eine spezielle Version mit einem x 1/4"? bilden? TPIS Außengewindeform an der Unterseite [ ich ernenne die TPIS später, wenn ich meine Stromeinheit verberge ]? das konnte meine ursprüngliche Fettspritze ersetzen Ich übersetze jetzt dieses zum Deutschen Ps - Ihre Web site und Bestandteile sind sehr eindrucksvoller...... bester Respekt Derek
Winfried - from Derek Warner in Australia
Greetings - I am a member of the Paddle Ducks WEB Group for model paddle wheelers [1000 members world wide] & found your WEB site posted recently by one of our  members
I have been building a 1: 24 scale 1878 built paddler & have a French [JMC] horizontal engine, a Scottish [ACS] boiler system & a French [Anton] gaz regulator - I enclose a snap
However I am most interested in your  .......Verdraengungsoeler-mit-Glaszylinder-400-110 [displacement lubricator with glass cylinder tube]
Question - would you make a special version with a 1/4" x ?? TPI male thread form at the base [I will nominate the TPI later when I dissassemble my current unit] ? that could replace my original lubricator
I will now translate this to German
PS - Your WEB site and components are very impressive......best regards Derek
« Last Edit: March 08, 2008, 12:01:38 PM by derekwarner_decoy »
Re: Steam Fittings
« Reply #3 on: March 08, 2008, 12:10:47 PM »
Hi PD's...couldn't resist the temptation   :whistle..so have ordered a 400-110 series glass tubed displacement lubricator from Winfried Niggel....'modellbau-niggel'
At EURO 28 + freight seems super cheap insurance with the clear visual in eliminating any chance of an engine getting a GUT full of water  :crash :sobbing as opposed to steam oil
Winfried confirms the base port tapping is M6x0.5P .......so in true OZ style I will  :hammer modify this & silver solder a 1/4" fitting to suit my ACS manifold
crash93
Re: Steam Fittings
« Reply #4 on: March 12, 2008, 10:10:39 PM »
Derek, Have yours arrived yet..? I have ordered some as well, but only at the weekend ,Posting to AUS can be very fast I sent some items to my Son in Karafa, I think that is the spelling and it took four and a half days normal post by royal mail. also did you know  he sells on ebay
http://stores.ebay.co.uk/Modellbau-Niggel
Peter
Re: Steam Fittings
« Reply #5 on: March 13, 2008, 12:18:30 AM »
Hi PD's....Crash.... Winfried Niggel seems great to deal with [electronically I mean] but it took a few days to clarify the correct Bank.......VEREINGTE SPARKASSEN ESCHENBACH 1DOPF.....DE7372>>>>>>>>>>>>>>>>>>>>>>>> Account
So I don't expect any goods for a week or so....
The costing is great @ ....EURO 28....but the DHL registered air bag was EURO 38  :ranting
The advertised product range from Modellbau-Nigel.de may be limited :crash...however I suspect he may supply others...check out the Monahan boiler package detail....recognise those round bodied transition piece fittings at the top of the boiler & also the same style round bodied fittings to the ...de Oiler?
Will certainly confirm  :goodnews when the clear view 'Oiler" arrives......
« Last Edit: March 13, 2008, 01:05:40 AM by derekwarner_decoy »
Re: Steam Fittings
« Reply #6 on: March 13, 2008, 05:10:47 PM »
Hi PD's.... :oops Crash...does your son live in Western Australia? ......if so it could be Karratha - Iron Ore mines & shipping it out to the world....many years ago I flew 2000km from Sydney to Perth & then 1000km from Perth to Karratha to attend an Australian National Line 100000 DWT ore carrier which had a problem with her main engine governor amplifer pump...but we soon fixed that  :hammer :yeahbaby :great :shhh & then we sent her back to sea  :goodluck :nahnah
Then I had to wait two days for my flight back home so enjoyed a  :beer & .....:vacation...and just for Bogstandard....no, I did not venture into the beautiful blue water...... :nono..too many poisonous sea snakes & blue ringed octopus things
But...getting back on line :offtopic....yes the postage between UK & OZ is great..all of my bits & pieces from Lochgilphead or and Crewe have arrived in the same 4 to 5 days  :towel
Monahan Steam Models Inc.
Re: Steam Fittings
« Reply #7 on: March 13, 2008, 05:33:30 PM »
Derek,
Sorry to disappoint you, but we have never heard of Modellbau-Nigel.de until now and certainly do not use any of their fittings in our products.
As we have said before, we make absolutely all of our parts in house.
I do have to agree with you, Modellbau-Nigel.de does have some nice stuff.
Best Regards,
Re: Steam Fittings
« Reply #8 on: March 13, 2008, 07:20:12 PM »
Hi PD's & hullo Nick....my comments were simply to acknowledge the visual quality of  :no1b  design style of minature steam fittings irrespective of the source of manufacture, which I had not seen previously.....regards  :towel
crash93
Re: Steam Fittings
« Reply #9 on: March 14, 2008, 02:46:35 AM »
Yep thats the place, but I think where he is working is some thing to do with GAS, he has just bought a house in Perth and flies up there for 6 weeks and back for a week , he likes it up there  :( ( probably the money helps) as there is nothing to spend it on ,so the house will be paid of quicker.
yes its supprising how fast postage can be for parcels but letters take two weeks.
Peter
crash93
Re: Steam Fittings
« Reply #10 on: March 31, 2008, 09:47:53 PM »
My two oilers arrived today , I got one of each. a friend in Germany ordered them and had them sent to him and he forward them to me , they look very good nicely made , should hold enough oil for a days sailing. I will have to make an adapter to use one of them as they are metric, I should have ordered a few more parts when I did this order so will have to start a list for the next lot.
Peter
Re: Steam Fittings
« Reply #11 on: April 01, 2008, 08:54:30 PM »
Hi PD's & yes Crash....my Verdrangungsoler 400 110 ..."glass tube displacement oiler" arrived today. :gift..& agreed as you say very good quality etc.....
What are you going to do  :crash with the 6.0 mm x 0.5 mm P internal thread?..........
crash93
Re: Steam Fittings
« Reply #12 on: April 01, 2008, 09:45:31 PM »
I was going to order one of there "t" Pieces but decided it would be easier to make one to mate to my Cheddar parts, did you know they have an ebay shop but do not sell very often.
Peter
Re: Steam Fittings
« Reply #13 on: April 19, 2008, 07:38:24 AM »
Hello, I have the glass oiler from Modellbau Niggel in my steam tugboat too. It's a very nice quality part, perhaps a bit large for some engines, but certainly nice to look at and I think it's good to be able to know how much oil you have left.
crash93
Re: Steam Fittings
« Reply #14 on: April 19, 2008, 10:46:22 AM »
any chance of a picture or two of the boat and installation please .I like to see how others have installed a plant
Peter
