Author Topic: My first paddler  (Read 4943 times)
Offline Broder Incertus
My first paddler
« on: August 31, 2006, 10:02:10 PM »
Greetings!
Since it survived its maiden voyage, and turned rather better than expected, and since I finally scanned them, some photos from when it was almost finished (it is still only al most finished, but it's getting closer).
Tissue covered balsa and liteply, more or less as simple as possible, improvised around the steam plant.
Cheers/tm
My first paddler
« Reply #1 on: September 01, 2006, 01:16:34 AM »
That's gorgeous Torbjörn, I love it!
More details please, steamplant fitted, length/beam of model, is it based on a full sized vessel?
My first paddler
« Reply #2 on: September 01, 2006, 02:56:40 AM »
Thanks! Not too bad for a first try (first boat I've built in 25 years) :)
Antón Quartz Horizontal, Graupner paddle wheels, two stage timing belt gearing, about 7:1; LWL 120cm, LOA 130cm, 15cm beam.
It's not based on any full size vessel, rather a caricature inspired by blockade runners and all sorts of paddlers, with a whiff of steampunk added.
Red_Hamish
My first paddler
« Reply #3 on: September 01, 2006, 06:33:03 AM »
Lovely stuff Torbjorn! I really like the lines of this one. You have made a great job of it.
Jim
Offline AlistairD
My first paddler
« Reply #4 on: September 01, 2006, 08:20:12 AM »
Is that based on a US Civil War blockade  runner?
 Â
 Alistair
  ----- Original Message -----
   From:    Broder Incertus (construction@paddleducks.co.uk)
   To: construction@paddleducks.co.uk (construction@paddleducks.co.uk)
   Sent: Thursday, August 31, 2006 1:02    PM
   Subject: My first paddler
Greetings!
Cheers/tm
-------------------- m2f    --------------------
http://www.paddleducks.co.uk/forum/viewtopic.php?p=8463#8463
Alistair Deayton
Paisley
Scotland
Re: My first paddler
« Reply #5 on: September 01, 2006, 02:32:53 PM »
Quote from: "AlistairD"
 Alistair
Inspired by rather than based on any particular blockade runner.
My first paddler
« Reply #6 on: September 01, 2006, 05:26:17 PM »
Hi PD's - Torbjörn, she looks great - one very interesting point is your mention of the  ANTON Quartz 2CC horizontal & shaft reduction ratio of 7 :arrow: 1
I understand & have read the ANTON recommendation on line & have copied a similar reduction roller chain drive [3.47mm pitch] of approx 8:1 for my JMC3H - [quite a number of OZ paddlers had exposed roller chain drives]
Thank goodness &  :bravo  the ANTON  site provided this information as my engine manufacturer did not respond to my e-mailed questions  :rant :offtopic re this specific question
Again a supurb build & I am sure all PD's will look forward your comments re stability/turning/engine/boiler.......... the list just goes on........regards Derek :D
My first paddler
« Reply #7 on: September 02, 2006, 02:21:39 PM »
The Quartz seems to  work very well indeed, but this being my first steam engine as well, I don't have anything to compare it with. Antón's automagic valves, la vanne coupe gaz automatique autonome, defintely works: I didn't keep track of the time and run out of water in the boiler, so it shut the the burner. One paddler dead in the water in the middle of the pond  :)
It seems to be reasonably stable, and turns better than I feared it would: 3m (very roughly) turning circle.
