Author Topic: Mixer for sidewheeler? or a differential  (Read 2708 times)
Sandy Johnston
« on: June 20, 2005, 02:46:59 AM »
been tossing this one around in head......might rattle a few
ideas...
How about using a junked rc dirt car's motor and diff...
By applyng rudder controls to a disk style break on each of the
"wheels" independant from each other, the other side of the
differential will speed up to compensate resulting in a turn - how
effective I'm not sure.
Ekelfekin
AK NZ
« Reply #1 on: June 20, 2005, 02:47:25 AM »
Hi Sandy - I posed this same question about six months ago & actually purchased two such
R/C car diff units which I will use with my twin motors
The real difficulity can best be described as a real motor vehicle with the rear end jacked up
& what happens? - one wheel goes in the opposite direction to the other - Derek
Dai Powell
« Reply #2 on: June 20, 2005, 02:48:14 AM »
Hi there ,
You may also consider the fact that with a vehicle with one
drive wheel off the ground, in most cases there is no power to the
one that is on the ground, so you go no-where fast, mind you this
doesn't apply to 4 wheel drive vehicles..........Dai
KC6OLD
« Reply #3 on: June 20, 2005, 02:48:43 AM »
I played with that idea for a bit, I talked to some Car nuts near here and
the brakes are all or nothing , I don't thik it would work with the precision we
need.
Dave
« Reply #4 on: June 20, 2005, 02:49:29 AM »
on Tuesday, December 02, 2003 10:08 AM, "Brett S Hallett" [probably the
greatest OZ authority
on vehicle windscreen motor drives] posted a few quisical comments off line
as below [but I wanted
to share them with the group]
> > Derek,
> > I have been observing your saga of trying to achieve motor control for
> >some
> > time now ( not without some amusement either!!)
> > It seems to me that your digging yourself a electronic nightmare, from
> what
> > I've seen of electronic controllers it seems that they don't work as
> >required
> > for a paddler ! What you have purchased might be the exception. :-) &
>>I am really looking forward to seeing you Decoy under power !!
> > Cheers,
& I responded as such
Hi Brett - have missed your comments over the past months & hope all is OK
with you
SOOOOOOOOOOOOO, yes it has been a little amusing & all started out with the
thought of Decoy steering like a dog & has grown like topsy [lots of black
box's]
I have the R/C gear on charge now & hope to do a trial [dry ] run of the
all
the electrics this weekend - so I'll post a response to all - regards Derek
PS - re-thinking the last sentence - with seven box's multiplied by say five
wires
per box [on average] to connect - it's probably best that I stay DRY until
the test
is complete
