on February 02, 2002 "Hal Harrison" <HarrisonHal@hotmail.com> wrote
> Derek, never, never change the length of the aerial wire, it is made a
> specific length to match the radio wavelength and receiver circuit.
Thanks Hal - a bit problematical as it was cut (by another) 18 years ago, so
have asked Futaba for help - and their response is amazing - as follows
regards Derek
To: "support Futaba" <support@hobbico.com>
Sent: Sunday, February 03, 2002 3:31 PM
Subject: Re: Futaba FP-4L - Aerial Length (-narrowband -AR)
> Thank you for the automated computer response, however the specific
question
> remains unanswered
> I would be most appreciative if one of your technical people could
> comment/confirm the Tx aerial length
> regards Derek Warner
> ----- Original Message -----
> From: "support Futaba" <support@hobbico.com>
> To: <derekwarner@bigpond.com>
> Sent: Sunday, February 03, 2002 3:19 PM
> Thank you for your recent e-mail. PLEASE NOTE THAT THIS IS AN INTELLIGENT
> AUTOMATED RESPONSE BASED SPECIFICALLY ON THE INFORMATION YOU HAVE
SUBMITTED.
> If this information does not solve your problem, please simply reply to
this
> email BEING SURE NOT TO CHANGE THE SUBJECT and let us know what is still
> occurring.
> IF IT DOES NOT ANSWER YOUR QUESTIONS, PLEASE SEE BELOW.
> "Is my radio currently legal to use"?
> Please see the F.A.Q. listed below, which includes a list of how to tell
if
> your radio system is still legal and lists all LEGAL AM radios as of 1998
> (anything produced 1991 or later is definitely legal.)
http://www.futaba-rc.com/faq/service-faq.html#q41>
> For example, is your radio a 4NL, 6FN, 4L, 6FN, FG series AM, 2PKA, or a
> 5LK? These radios are not legal for use in the US at this time and CAN
NOT
> be made narrow band. Some of these radios do have some collectors value so
> you may wish to consider selling them to a collector.
> "Can I still use my old servos (with the pins sticking out, called G
> plugs)?"
> Yes, if the servos operate, you can buy G to J adapters so they will plug
> into the current generation receivers. Again, it may be worth considering
> replacing them, though, with the newer, better technology.
> "Can I get a manual for my older radio?"
> If your radio is listed in the discontinued chart on this page:
http://www.futaba-rc.com/manuals/index.html> then the manual is available as described. If it is not listed here then
we
> do not have a manual available for you.
> "I know my radio isn't legal. Can I use it as a trainer box?"
> Unfortunately no. The old pre-1991 radios used a different trainer socket
> which is not compatible with the current generation equipment. We
apologize
> for any inconvenience but it is against FCC regulation for us to assist
you
> in any type of cable set up, modification, or other efforts to work on or
> utilize this.
> "I know my radio isn't narrow band, but can you help me with xxxx anyway?"
> Under FCC regulation we MUST NOT assist you with a non-legal system in any
> manner, including providing parts numbers, etc.
> Assuming you are in the US, your radio is illegal to use, against FCC
> regulation. It is also dangerous to your models and to others flying in
your
> area as well as potentially hazardous to those utilizing the primary use
> bands between our channels (such as remote controlled construction cranes,
> etc).
> These radios remain legal in Canada as well as many now being collectors
> items due to their age, so you may wish to consider selling the item to
help
> fund its replacement. PLEASE BE SURE TO ADVISE YOUR PURCHASER that the
radio
> is no longer legal in the US.
> "My transmitter is narrow banded but my receiver is not on your list. Does
> this mean it is not narrow band? Is this bad?"
> If your receiver is not listed it is not narrowband. It IS still legal to
> use; however, you are far more likely to receiver interference on a wide
> band receiver, from other modelers are close frequencies and from other
> users such as pagers, cell phones, etc. We recommend replacing your
> receivers.
> Please note that we do not service cirrus radio equipment.
> Did this answer your question? If so, we're thrilled to hear our
automated
> assistant was able to point you to the information you needed so promptly.
> If not, please reply to this email BEING SURE NOT TO CHANGE THE SUBJECT
and
> including this entire email in your response, and let us know how else we
> can assist you. Please note that your original email has been deleted
after
> this automated assistance, so you must reply to this email to have one of
> our technicians answer you personally and promptly.
> I hope you find this information helpful. Should you have any further
> questions or concerns, please do not hesitate to contact us at this email
> address. (Please be sure to copy all previous emails into any future
> questions.) You can also reach our product support technical team at
> 217-398-8970, or via fax at 217-398-7721.
> Sincerely,
> Futaba Support AUTORESPONDER
www.futaba-rc.com>
> >>> "derekwarner@bigpond.com" 02/02/02 21:16 >>>
> Good morning Futaba
> I purchased a Futaba FP-4L set in Australia (TX frequency is 30.200 MHz
and
> the Rx is 29.745)
> some twenty years ago however the TX aerial has been inadvertently cut
> Could you please confirm the correct total length for the TX aerial
