Author Topic: Leakage: Minimising thereof.  (Read 8028 times)
Offline Andy F
« on: October 06, 2021, 02:36:58 AM »
What's the most reliable way to minimise leakage around paddle shafts?
Many years ago I used to use a patch of oil soaked leather which worked very well but tree huggers seem to go apoplectic at the very mention of oil these days.
That said, that was for shafts that weren't immersed in water. My latest project calls for 6 shafts that will be fully immersed all the time.
Anyone got any ideas?
Re: Leakage: Minimising thereof.
« Reply #1 on: October 06, 2021, 03:27:04 AM »
You can get sealed bearings if they are available in the correct size for your shafts?
Offline Andy F
« Reply #2 on: October 06, 2021, 04:11:20 AM »
I must admit, I never thought of actual bearings  ::)
Found some now that should do the job fine and only £1.54 each. Result :)
Cheers.
EDIT: Sorry this was in the wrong place, it's been a while.......
« Last Edit: October 06, 2021, 04:17:11 AM by Andy F »
« Reply #3 on: October 06, 2021, 08:21:10 AM »
This is a Grade 316 S/S shell + ZZ shields bearing to suit a 1/4" shaft........[smaller sizes are available]
Bearings would be available from any bearing distributor, alternatively available complete in the miniature Plummer Block from SPD/SI in America [or SPD/SI distributors World wide]
ZZ stainless shaft bearings are not listed as waterproof, however delete the ZZ designation & substitute 2RS for a synthetic seal which is listed as hose down proof [for the food industry]
I understand our applications [shaft above water level, but splashed on], generally would not see a lot of water in their life time, however as shiny & cheap carbon steel bearings maybe, I would be hesitant in using them in conjunction with water
Keep us posted on a 3 shaft Paddler?
« Last Edit: October 06, 2021, 01:21:53 PM by derekwarner_decoy »
Online Spankbucket
  • Emigre from South London
« Reply #4 on: October 06, 2021, 05:27:35 PM »
I would stow your concerns regarding the approbation of those arborial clasping bigots! Any reaction you provoke in them is indeed a pink sea fish!
Any one these days would use a vegetable oil by definition so their false arguments are irrelevant.
What about a nice drop of Italy's finest?
Or are there surrogate flesh eaters out there that wish to preserve turnips?!
Offline Andy F
« Reply #5 on: October 06, 2021, 07:30:43 PM »
That made me smile. I've not seen a finer example of pleonastic polysemy and synonym usage in a long time.
Well done Sir 8)
Online Spankbucket
« Reply #6 on: October 07, 2021, 03:46:45 AM »
Thank you so much; I appreciate your comments very much.
I am currently going through a severe attack of creative writing and a strain of it popped out here!
