Author Topic: Boiler feed steampump, shuttle valve problem solved  (Read 4042 times)
Offline JohnNL
« on: July 31, 2021, 06:13:47 PM »
Dear live steamers,
We all know the stand alone boiler feed pumps, and they all share one problem:
The steam valves, they must be precise, and the smaller they get the harder it is to run them with live steam.
I found a solution to get rid of the shuttle valve.
I explain it in this video i made last year.
https://youtu.be/r0g-yjBVuYA
« Last Edit: July 31, 2021, 11:30:11 PM by JohnNL »
Re: Boiler feed steampump, shuttle valve problem solved
« Reply #1 on: August 01, 2021, 08:26:06 AM »
Hullo & welcome to PD's John
......first the steam plant & now this little boiler feed pump with neo-magnet valve holding function :bravo
This must have been quite a bit of trial & error, as these little magnets [with varying gauss] are extremely difficult to pull apart in a straight linear movement
This is indeed a very intelligent method of achieving ....as you have said 'a difficult challenge' :ranting
My involvement is associated with 5" Gauge engines, and their builders often note....many of their steam-driven feed pumps are problematic, and they rely on the larger axle driven pumps
Well done & happy boating under steam
Derek  :beer
« Last Edit: August 01, 2021, 08:30:45 AM by derekwarner_decoy »
Offline JohnNL
« Reply #2 on: August 01, 2021, 06:31:19 PM »
I also own a Clayton undertype steamwagon in 2" scale.
I've build this one in 10 years and its a happy running on a flat road.
This one also relies on the axle driven pump, i fitted An injector, but operating while driving is a challenge.
I am intending to fit this steampump in the cab, i already removed the injector.
Happy steaming!!
