Paddlewheels/Drive Systems
Mountfleet Waverley
Topic: Mountfleet Waverley (Read 9908 times)
DavidM
Junior Member
Mountfleet Waverley
October 30, 2020, 02:57:36 AM »
I'm waiting for delivery of a Mountfleet Waverley which is 1/53rd scale 54 inch long and 11 beam across the paddles. I'm trying to get some paddles ready for the build I've got no machining available just bench work so I'm looking to either shapeways for 3d printing or model engineering laser both arent cheap and as a bonus model engineering laser is retiring in the next two weeks and is taking last orders. What size paddle wheels am I looking for? I've tried to contact Mountfleet by phone and email to no avail can you help in any way to alternative suppliers of tell me what size to order.
By trade I'm a qualified press tool maker so the engineering side doesn't scare me it's the facilities I'm lacking in.
Oh my!
Barry
Re: Mountfleet Waverley
October 30, 2020, 07:36:17 PM »
See the last page of Float a Boats May 2009 news letter. Their kit is based on the Waverley's paddle wheels.
https://www.floataboat.com.au/Newsletters/2009/FAB%20N_letter%20May%2009.pdf
DavidM
Junior Member
October 31, 2020, 04:33:03 AM »
I've got that newsletter as I'm really piling on the research, I take it I need the larger diameter for my size hull?
Mountfleet must be on holiday I've not been able to contact them all week and this is proving to be the only sticking point im coming across , everything else is on here!
Oh my!
Barry
October 31, 2020, 07:48:41 PM »
I think it would be the smaller size. Probably best to get the hull/plans and check before you order anything.
There is a drawing of Waverley's paddle wheel in the down load section. You could see if it's got dimensions on it and scale it to you hull to see what size you need.
DavidM
Junior Member
October 31, 2020, 10:16:34 PM »
Float a boat have replied and I think I'm okay for paddle wheels, I think I have been fretting about this too much there's more options than I thought.
Oh my!
DavidM
Junior Member
July 07, 2022, 07:21:52 AM »
I'm getting well into my build now and the more I'm going I'm getting more confidence so much so I may do my own paddle wheels, I'm veering towards plastic as it's light and easily worked. The plans i have are 97mm outside diameter rimless wheels the question I've got is 2mm thickness for the outer wheels sufficient or overkill?
Last Edit: July 07, 2022, 07:27:27 AM by DavidM
Oh my!
July 07, 2022, 09:21:37 PM »
David...
depending on the design of reinforcement,
2 mm width plastic
x a nominal 100 mm rimless design of paddle wheel would not be out of visual scale
DavidM
Junior Member
July 08, 2022, 06:52:26 AM »
Thanks Derek I thought it wasn't too over the top the only thing is I want longevity so I'm casting round for idea's I've had a decent quote for laser cut paddles in brass which has sent my brain down another path. I'm absolutely loving building this boat the little challenges that keep cropping up with it.
Oh my!
Mountfleet Waverley
