Author Topic: Another Waverley  (Read 5357 times)
Offline Sabre
Another Waverley
« on: March 31, 2020, 10:48:49 PM »
Not long started this and I can't believe the photo came through.    I'm using 3mm  lite ply for the frames and I intend using 2mm lite ply for the planking.  When the hull is finished it will get a coat of fibreglass resin both inside and out.  A bit cold in the garage still hence the slow progress.
« Last Edit: March 31, 2020, 10:54:10 PM by Sabre »
Re: Another Waverley
« Reply #1 on: March 31, 2020, 10:59:04 PM »
Progress is looking good so far - What scale are you building at?
I'd mount the frames onto a building board before attempting the planking though, otherwise it's likely to twist out of shape.
Offline Sabre
« Reply #2 on: March 31, 2020, 11:55:41 PM »
https://www.cornwallmodelboats.co.uk/cgi-bin/sh000001.pl?WD=waverley%20p%2es%2e&PN=mar2283%2ehtml#SID=197
Can't remember the scale but it's just over four feet in length.   I've done a couple of plank on frame kits before and I intend doing just a couple of planks at a time whilst the thing is kept upside down and suitable weight on top.   After cutting out the frames I realised that  3mm lite ply is just a bit too flimsy.
Offline Sabre
« Reply #3 on: April 24, 2020, 12:25:17 AM »
I've been plodding along with the build over the past few weeks and today I cut the deck from a sheet of four feet 1.5mm ply which I have had for years.   A few mistakes have been made but some are easily overcome whilst others remain a bit tricky.  Paddle boxes are not finished and only placed alongside.
Just wondering what is the easiest / simplest way of powering the thing.
Hopefully the images attach ok.
« Reply #4 on: April 24, 2020, 02:27:32 PM »
 :clap :clap :clap :clap :clap :clap :clap :clap :clap
Offline Sabre
« Reply #5 on: April 17, 2021, 09:36:57 PM »
Still plodding on with it but it has progressed a lot more than in the attached photo.   Oh how I hate modern paint.
