Paddlewheels/Drive Systems
Coupling the 8mm gearbox shaft to the 4mm paddle shaft?
Topic: Coupling the 8mm gearbox shaft to the 4mm paddle shaft? (Read 11803 times)
Nemo
Junior Member
July 08, 2018, 08:40:29 AM »
I bought the Heng Long dual gearbox (150 rpm) units from Bangood. seems one side has an older motor than the other as it is more noisy and possibly not as fast. but close matched speed doesn't matter as they will be mixed, eventually.
For now I am asking for help on how to connect the shafts. Be assured that I have no real idea how best to do this.
The gearbox shaft has a flat and has a small diameter threaded tapping (if that's the term).
I bought the Paddle kit from Floataboat (visit that place with a fat wallet and no wife) and have made them up.
I'll set up everything on a board before even thinking about the hull construction. I bought the P.S. Alexander Arbuthnot plans ($A55) which are seemingly well presented. Figuring them out will be a hefty learning curve, methinks. Was advised to go with that rather than the more complicated hull of the Adelaide.
Thanks in advance
Mal
Third time lucky
Re: Coupling the 8mm gearbox shaft to the 4mm paddle shaft?
July 08, 2018, 11:59:53 AM »
Morning Mal.............
Firstly, the Float a Boat plans are well drawn and represent the respective original vessels quite well...[I have the FaB plans for the Adelaide and Oscar W]
150 RPM is a good starting speed for a 1:20 scale paddler, however if direct drive onto the paddle shaft's is intended, you many need to use full motors speed as a starting point....gearbox noise may or may not be an issue
Universal shaft couplings are relatively inexpensive and are ideal for the low rotational speed we use.......[there are 100's to choose from, although 8mm diameter will limit your selection, or dictate that you may need to bore a coupling half to suit this size] ...just [google Model shaft couplings]
Action Electronics from UK produce a series of speed controllers for twin propeller vessels, however are of course suitable for a twin motor paddle drive. These controllers provide proportional motor speed on one stick of your R/C transmitter....and naturally also provide the same in reverse for astern rotation [ Component Shop UK.......they now market the Action range]
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwi2qo-LrY7cAhUBt5QKHfapCoAQFggoMAA&url=https%3A%2F%2Fwww.componentshop.co.uk%2F&usg=AOvVaw17KPJps4vXoxqzpMIq9YHY
Using one of the above controller's will eliminate any bias or difference created with the twin motor setup with 2 independent shafts and provide tank type steering.......however if you study the subject...
....you may find this method of control not to your liking
Now saying this, no Australian paddler had independent shafts........after a number of incidents in the UK, dual shaft paddle drives were outlawed for passenger ferry work
Keep us posted with your progress ...any specific question...just ask ..........Derek............
Nemo
Junior Member
July 10, 2018, 09:47:46 AM »
Following your advice I find I can get a 8:4mm reducer and a 4:4 universal. If I connect those with a short 4 mm shaft (hardened steel ) it should suffice?
I think maybe the Heng Long gearboxes was not a good choice, the noise I can reduce, or ignore, but the quality of the units leaves a bit to be desired. One rotates with 6.6v at 125 rpm, steady, the other (the newer looking motor and build) varies 3 or 4 revs under no load.
Just in case, I’m looking on eBay for alternatives, either one with a left and right shaft for direct coupling, or 2 units to use as I had in mind with the ones I have.
For instance, this one.
https://www.ebay.com.au/itm/12V-DC-160RPM-Turbo-Worm-Geared-Motor-Dual-Shape-Shaft-Electric-Power-Reduction/282924589340?epid=17011016061&hash=item41df9ea11c:g:GYcAAOSwRdta0cCI
Do the paddles require a lot of power once under way? And what do you suggest in rpm for this model (36” ) ?
Thing is, what parameters should I look for?
I appreciate your help
Mal
Third time lucky
July 10, 2018, 12:04:11 PM »
Mal......the 12 volt worm & worm wheel electric drive you show is very similar to the old windscreen motors that many members used years ago for paddle drives
The worm & worm wheel provides a
very quiet and stable drive
with very low current consumption.......these were not on the market 25 years ago
Having dual output shafts concludes that endfloat is taken up internally which is a bonus...so only one motor assembly would be required
Using a single motor also means that your choice of an electronic [
Action brand
] speed controller is less expensive.......the electronics controlling these modern day devices does not provide a reduced voltage to power the motor, but some form of wizardry in pulsing the applied current to slow the motor.....again all very stable without any jerkiness
The dual 7mm diameter output shafts could be accommodated with a pair of universal couplings...and a massive 10kg of stall torque on the shaft
All in all, mechanically, electrically and with a very high reliability promise due to the robust design a very good choice and @ $25.00.. a bargain
Your ESC will cope with zero RPM to full RPM without overheating or shuddering and you may find that whilst 100 RPM is fine for top speed....windage does play a part in model boats performance and it is always good to have extra reserve of blade power [150 RPM] if needed
So to answer your question on the paddle blade force to push a say 15 kg paddler.....is very complex to answer
However in reality you could place one finger on a 150 tonne vessel moored at the dock, and you will move the vessel
Model scale rules?......
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0ahUKEwjnyP-LtpPcAhUFKZQKHb21DQMQFghbMAo&url=https%3A%2F%2Fwww.modelboats.co.uk%2Fforums%2Fpostings.asp%3Fth%3D33155&usg=AOvVaw1qyeNUyFnb6coBCYxhCOMY
Remember your Alexander Arbuthnot's river speed is only ~~6 to 7 knots…….so importantly your model will never be a speed boat
PS....[I have no association with Action products.......just a very satisfied customer over 20 years]
Last Edit: July 10, 2018, 07:45:56 PM by derekwarner_decoy
Nemo
Junior Member
July 10, 2018, 06:48:12 PM »
Thanks Derek, you have explained everything very well and I'm more aware now of what is required.
Since I've ordered the bits to convert the 8mm to 4mm I'll set that up on the bench and play around with the system, checking my stocks of speed controllers.
But I'm pretty sure I'll get the larger, more simplistic worm gear unit and make things easier from the start.
Thanks once again for your speedy and very clear advice.
I'll keep you posted on what I come up with.
Mal
Third time lucky
Nemo
Junior Member
July 12, 2018, 07:32:56 AM »
Ah, I've come to conclusion that the Heng Long motors are likely to be a hat full of problems despite being so optimistic when buying it. Oh well
I will bench test them anyway but in the meantime have ordered the dual worm gear unit plus converters to use the 4/4mm universals.
Being 12v ( I think they will take up to 18v but 12 will be fine. Actually I'll be using a 3S LiPo Battery which is nominally 11.7v so that's fine.
I notice some gearboxes, mainly the single shaft type, are available in brushless. While not as efficient , the brushed is reversible. not sure on Brushless. I know brushed are able to operate under water, but sincerely trust I will never know for sure from any dire experience..
As an aside, any Aussies buying on eBay will now notice the ATO getting their 10% GST. Fair enough. Same with Amazon.
Third time lucky
July 12, 2018, 09:56:26 AM »
10% is way better the the original suggestion of $10 tax for anything bought costing upto $1000 I've noticed a lot of chinese and hong kong ebay sellers now having supposed warehouses in Aust, but goods arrive from offshore.
And paypal are withdrawing the tax separately from the purchase price from my bank.
Nemo
Junior Member
July 12, 2018, 11:02:55 AM »
Yes, I agree.
Third time lucky
Nemo
Junior Member
August 26, 2018, 04:37:49 PM »
Well I finally got to do a simple bench rig to see how it looks.
For the video I just used 6 volts since the nominal 12 volts made it took like a turbofan! (what you might expect for 150 rpm).
More than happy with the drive, so quiet and no vibration at all.
The paddles are the FAB laser kit ones, they were pivotal as to whether I would even attempt this project, and from what you see here I think I'm good to go with proceeding with the Alexander Arbuthnot build. That is in a queue for now but hopefully getting underway in a month or so.
But for now I'll set up a brushed speed controller and check that out.
https://youtu.be/QtFFLHmcrpo
Third time lucky
Reply #9 on:
August 26, 2018, 07:02:34 PM »
Nemo
Junior Member
Reply #10 on:
August 26, 2018, 07:19:05 PM »
Thanks Damian, exactly how I feel about it
Third time lucky
