Author Topic: Heng Long gearbox specification  (Read 7294 times)
Offline Nemo
« on: June 15, 2018, 12:29:25 PM »
I'm trying to work out which unit to get to drive a 1:26 The Alexander Arbuthnot side paddler.
None of the ads seem to provide  default RPM out data.
Can anyone suggest which model of the Heng Long range should I go for?
I assume that a pair of speed controllers would be able to adjust the actual paddle revolutions.
What  range should the paddles nominally rotate at ?
I realise these are  newbie type questions so please allow for my ignorance.  ;D
Third time lucky
Offline TailUK
Re: Heng Long gearbox specification
« Reply #1 on: June 15, 2018, 06:00:21 PM »
I measure the output of the ones I've got at around 150 rpm but that was without a controlled supply (just hooked up to a battery)   I think the required RPM really depends on the diameter of the wheel.
Offline Nemo
« Reply #2 on: June 16, 2018, 04:13:11 PM »
Thanks for that, more  or less what I had gleaned from other posts.
I bit the bullet and bought laser cut paddles for the boat I'm emulating, The P.S. Alexander Arbuthnot, a working  Murray river (Australia) side paddleboat.
https://www.youtube.com/watch?v=ViQSZUKoeK4
They are 120 mm diameter.  7 paddles
« Last Edit: June 16, 2018, 04:16:30 PM by Nemo »
Third time lucky
