Author Topic: Josie Olsen  (Read 61635 times)
Re: Josie Olsen
« Reply #120 on: March 22, 2018, 03:58:07 PM »
Thanks Gerald,
I put the digital tachometer on it with 12v supply from my power supply built at Tech school way back in the seventies it gave 57.75 rpm at these rev's the beam was rather slow although it runs very smoothly.
My camera takes stills & video but I can't workout the video part :'( :'( :'( :'(
Re: Josie Olsen
« Reply #121 on: March 24, 2018, 06:21:26 PM »
New pulley turned a little under double the diameter of the original, still have to drill & tap for the grub screw the pic also shows the spring I'll somehow attach to apply light pressure the drive belt.
Re: Josie Olsen
« Reply #122 on: March 25, 2018, 05:36:52 PM »
The new pulley increases the wheel revs to 79 rpm so I removed the main pulley chucked it in lathe and reduced the diameter by about 5mm then cut the new pulley groove put it back together and the batteries ion the tacho were flat, tomorrow's another day.
That will be spent vacuuming the dust from machining the body filler main pulley it's everywhere.
« Last Edit: March 25, 2018, 05:40:08 PM by DamienG »
Offline Delaunay
Re: Josie Olsen
« Reply #123 on: March 25, 2018, 07:26:35 PM »
 :) Hello;
It seems to me that your "strap" is very loose (not tight enough), no; and is it glued with cyanoacrylate glue.
Re: Josie Olsen
« Reply #124 on: March 25, 2018, 07:58:41 PM »
I know you were having problems with video Damien, but I'd love to see a video of it in action if you can manage it?
Re: Josie Olsen
« Reply #125 on: March 25, 2018, 08:09:42 PM »
I was holding it tight While doing the tests, I still have to make the attachment points and the rod for the centre of the spring.
Eddy I've worked out how to take the videos I just have to learn how to put them on youtube now.
Can anyone give me an estimate of the expected paddle RPM please?
Re: Josie Olsen
« Reply #126 on: March 26, 2018, 03:14:15 PM »
I've got it recording Just have to figure out how to post to youtube now. lol
Re: Josie Olsen
« Reply #127 on: March 29, 2018, 07:21:20 PM »
A piece of scrap 8mm plywood solved the belt tension hassle.
The pulley mod's produced 123 rpm
As requested Eddy Motor & beam in action.
https://youtu.be/Jhp-iL65hL0
« Last Edit: March 30, 2018, 12:52:39 PM by DamienG »
Re: Josie Olsen
« Reply #128 on: March 29, 2018, 08:12:59 PM »
Looks really good in the video Damien - A job well done!
Re: Josie Olsen
« Reply #129 on: March 29, 2018, 10:24:29 PM »
Thanks Eddy.
Some 3mm spiked nuts arrived today I'll put them in hull tags to hold the motor assembly in place tomorrow.
Offline Delaunay
Re: Josie Olsen
« Reply #130 on: March 30, 2018, 04:30:24 PM »
 :) Hello
Top  :clap :no1b
Re: Josie Olsen
« Reply #131 on: March 30, 2018, 04:36:33 PM »
Thanks matey.
Re: Josie Olsen
« Reply #132 on: March 30, 2018, 06:02:36 PM »
Nuts fitted my guess of keel to motor clearance was a close call if the belt stretches even a little the motor tray will hit the keel.
with top 2 decks in place she looks good.
A few more picks.
There's not much room inside for the radio and batteries I've ordered 10 x 6ooo mAH sub C batteries on ebay I'll build 2 packs of 5 cells and velcro them to hull walls then worry about the Rx & Rx battery then think on the speed controller placement.
Offline Delaunay
Re: Josie Olsen
« Reply #133 on: March 30, 2018, 07:44:08 PM »
 :) Hello ;
It's getting more and more fun, a big cheer Damien  :clap
Re: Josie Olsen
« Reply #134 on: March 30, 2018, 08:15:51 PM »
 :beer :beer :beer :beer
