Author Topic: R MURRAY  (Read 6442 times)
Offline Delaunay
R MURRAY
« on: December 09, 2016, 03:52:27 AM »
Hello;
I allowed myself to make an interpretation of the boats of the MURRAY River of AUSTRALIA.
After having watched the videos and documents found on the net, I made a free interpretation; That's recovery for materials.
A vague sketch for the follow-up and many modifications during the construction.
Do not worry about the holes in the plating and do it; The plating will be doubled with 1.5 mm plywood and done with 3 mm.
Whatever photos on the beginning of the works with the steam engine coming from the Gulnare.
cordially
Hébergé par Imagesia.com
Offline bill stafford
Re: R MURRAY
« Reply #1 on: December 09, 2016, 05:25:07 PM »
i would f/glass the hull, inside and out.
i did mine 12+ yrs ago , no wear or splits
keep it light , especially the paddle wheels and supers., i did mine in hips , scored the wooden plank lines into the HIPS or ply ,to give the wooden join lines effect.use a sharpened hack saw blade or glass cutter
watch the paddle boxes, these need to be light , yet strong, i put a 10/12mm sqare wooden section in front and behind the p wheel , strong enough to deflect any object from hitting the p wheel
Offline Delaunay
Re: R MURRAY
« Reply #2 on: January 13, 2017, 02:58:03 AM »
 :) Hello !
A p'tite suite in photos
-The bottom of hull will be finished with a CtP of 1,5 mm aviation
Hébergé par Imagesia, le meilleur hébergeur d'images du net !
-Pose of border in CtP of1,5mm aviation
The hull sanded with the temporary machine
The preparation of the openings for the "wings" of the wheels
The beginning of the installation of supports
The reinforcements of angles on the "wings"
« Last Edit: January 13, 2017, 03:43:56 AM by Delaunay »
Re: R MURRAY
« Reply #3 on: January 13, 2017, 08:16:23 AM »
Bonjour François  :coffee
The hull will be very strong...possibly a few additional supports under the boiler and engine space?
The inverted twin Oscillator engine will look beautiful....yes  :kiss1 when on view and running.........what fuel will the boiler use?
Please keep posting images of your build.......but you must tell that little scale shipwright man to keep his fingers away from moving machinery  :hehe
« Last Edit: January 13, 2017, 06:42:55 PM by derekwarner_decoy »
Re: R MURRAY
« Reply #4 on: January 13, 2017, 04:42:28 PM »
Very nice build  François :kiss1
Offline Delaunay
Re: R MURRAY
« Reply #5 on: January 14, 2017, 03:52:01 AM »
 :)Hello;
Derek, the hull made only 1.5 mm and the pit keels 15 mm strongly open, there are reinforcements under the boiler and the machine.
The machine is a dual twin effects of 18mm bore and 36mm stroke.
The boiler is 4 boiling tubes, its Ø is 60mm for a length of 160mm, gas heated by a single small mushroom
The little dog "pif" is always on these guards and wise. ;)
Thank you Damien!
Sincerely yours
Offline Robert Hornby
Re: R MURRAY
« Reply #6 on: January 15, 2017, 01:04:02 PM »
Lovely job there Francois, Looking forward to following further progress. :bravo
Robert
Offline Delaunay
Re: R MURRAY
« Reply #7 on: January 24, 2017, 03:30:37 AM »
 :) Hello ;
It was nice (I mean not cold) so a sequel;
The (always) installation of the supports of the decking of the continuous wings with that of the corner reinforcements
Always the same thing
Well I see the end :shoot
A few hours of work, and I could make the beginning of ... the end?
cordially
Offline Delaunay
Re: R MURRAY
« Reply #8 on: February 17, 2017, 04:49:40 PM »
 :)Hello;
The end of winter is approaching and the workshop becomes more frequentable, so after work in the garden to prepare for the coming of spring, I go back to my den and the first questions about dressing my R. MURRAY are on The overlap of the bridge (s).
  1 / the deck (the one above the hull) in which wood essence was it commonly made and was it raw, varnished or painted?
  2 / The lateral bridges, are they with slats joined or separated; Again, was the wood raw, varnished or painted?
I speak for a general practice, because my R. MURRAY is only an extrapolation of my research on the net. It is a boat of "work" and not of tourism.
cordially ;o)
François
Offline Delaunay
Re: R MURRAY
« Reply #9 on: February 25, 2017, 05:42:09 PM »
 :) Hello !
It's nice and almost finished spring activities, I'm going back for a ride in my niche and is morning replacement of the base (heavy, very heavy) of the machine by a aluminum; I will have to have shorter screws 3 X 7
406gr of saved a nice output of winter diet lol
The implementation of the machine needed to make media machines (6); They are made in brass, Ø 6 x 5 base and some threaded M3 x 10, all stick to Epoxy in a base in Cpt.
Reservations with my old milling machine
I have completely disassembled, cleaned and reassembled the machine with its new base, two p' videos amounts of test
https://www.youtube.com/watch?v=cHD1UQ0SOSA
https://www.youtube.com/watch?v=1Dd8y-Z9KGo
 :coffee
