Author Topic: bow mast on paddles N.Z.  (Read 4887 times)
Offline Delaunay
« on: April 23, 2016, 04:59:29 PM »
 :) Hello ;
By reading different subject on the New Zealand boats with wheels, I board noted that some of these boats had a mast on the front.
I ask myself what this mast could it serve?
Certainly they are a some that are derricks, but then not mouflage for package handling and are set.
Someone should answer?
cordially
François
Re: bow mast on paddles N.Z.
« Reply #1 on: April 23, 2016, 05:15:48 PM »
Dear François.....those masts [or tree trunks :whistle] on river paddlers both in New Zealand and Australia were to help the Skippers or Captains line up & gain an accurate knowledge of the vessels bow  position
This is distinctly unique in narrow river waterways over open sea navigation
Offline Roderick Smith
Re: bow mast on paddles NZ & Australia.
« Reply #2 on: April 30, 2016, 06:35:01 PM »
That was my first lesson when steering on a big paddlesteamer.  You line up the mast on a desired landmark, then watch the swing of the mast, and back off before overshooting.  Part way around a corner, pick the next landmark.  I use the same method with my much smaller boat. Novices tend to overcorrect, then advance in a series of S curves.  On the river, currents and wind keep affecting the desired smooth line.
Roderick
Offline Delaunay
« Reply #3 on: May 01, 2016, 01:53:10 AM »
:) Hello ,
Thank you to both of you for the explanation.
I understand the difficulty navigating the narrow rivers.
cordially
François
Offline Delaunay
« Reply #4 on: May 12, 2016, 02:42:35 PM »
:) Hello;
By reading and looking at the Forum and on the net, I ais view that these ships could made the barge towing.
But I did not find, on photos, videos or drawings, how we fixed tow and what are the means of reinforcement of the structure, because it seems to me that this towing was from the top of the rear superstructures?
Kind regards
François
« Reply #5 on: May 12, 2016, 06:37:36 PM »
François.....if you view images of Australian paddlers, many will confirm the towing post is above and about the same height as above the axis of the paddle shaft
The basis for this is basic mechanics  with regard to the ''push/pull" point being the same as the axis of the drive which means that the rudder will function...[and change the direction of the vessel]
The image below confirms the towing post axis, together with the cables in tension no matter what loading direction is placed by the towed load/barge  :hammer
« Last Edit: May 12, 2016, 06:41:33 PM by derekwarner_decoy »
Offline Delaunay
« Reply #6 on: May 12, 2016, 09:59:17 PM »
 :)Hello Derek
And thanks for the information! I understand the principle.
Kind regards
François
