Author Topic: Small oscillating engine and gear box suitable for a small model paddle boat.  (Read 8811 times)
Offline Tony Bird
I have done a bit of R&D for a friend on a gear box for a model paddle boat.  The steam engine that will power it is a single acting oscillator with an 8mm bore and 16mm stroke it is based on a Mamod size I think; so there isn't a lot of power to play with.  A successful gear box with this size engine has been made using spur gears but a more compact one using a worm drive was desired.  A couple of gear boxes using heavy brass gears have been made but they had too much friction.  The hull to be driven is basically to the Mini Vap 50 rule it being just over 20" long and works quite well using the engine driving the paddles through a spur gear box.
The gear boxes that have too much friction.
So I am trying nylon gears.
The spur gear box using a 16:1 ratio drove a pair of 3.1/2"paddles easily.   So a prototype engine and wheel and wheel gear box was made.  The prototype gear box was designed so it could easily be made with different gear ratios.  First an 18:1 ratio was tried; having a slightly lower ratio was used to overcome any higher friction that a worm and wheel gear box might have.
With the engine support fitted.
A cylinder was made using a K&S brass tube.
A balanced flywheel was made.
The steam ports were drilled in the port block using a jig.
As there is no means of lubrication in the model boat a long aluminium piston was used.  I have found the combination of an aluminium piston working in a brass cylinder works well with saturated steam.
Checking the piston steam port clearance.
Checking the finished engine and gear box using steam.
With a boiler pressure of 20 psi it was found quite difficult to stop the engine by gripping the output shaft.  So it was decide to build a lighter streamlined version using the same gear ratio of 18:1.
For the engine/gear box frame some 1" square tube with 1/8" thick walls was used.
The same cylinder, piston and flywheel sizes were used.
The finished engine.
The two engines/gearboxes built.
The gears used were supplied by S.H.G. Models; the push fit gears are more concentric in use than the gears with bushes and were used on the second engine.  The cost of the worm and wheel was £3.50; I quite like using well made nylon gears they are quieter running than brass and seem to wear very well.  I have some 20 year old model railway locomotives that regularly have a lot of use which whose nylon gears are still in good condition.
The second engines port block has been designed if necessary to be large enough to take a double acting cylinder.  Using a thick wall square tube to make the engine mount means that bearings don’t have be used.
Video of prototype engine in steam at.
https://youtu.be/VmcpC5wAd5o
Streamline engine in steam at.
https://youtu.be/0hNhS5_UVF4
If there are any questions please ask; but from tomorrow I am away for some time to where the internet isn’t that reliable so it might be a while before I can answer.
Regards Tony.
What a great little pair of small engines well done Tony.  :clap :clap :clap :clap :clap
Offline Sekim
I agree potentially an excellent introduction to live steam.  Could Tony be tempted into giving a few dimensions such as the port sizes in the standard and cylinder?
Similar gears are also available on line from Technobotsonline.com.  I have had excellent quality steel and plastic gears from them at reasonable cost and a fast mail order service.  Mike
Offline Tony Bird
We are away on holiday until 20th. February and I am doing some drawings of the engine and its gearbox but won't be able  to copy them until I get home.  So if I forget to post them remind me!
Regards Tony.
The brass engines look really nice and compact. But I think they would both benefit from not too small flywheels.
Offline Tony Bird
I agree but I think the flywheels are to the spec's I was given 30 mm diameter and 6mm thick; the one flywheel has had its sides removed for some reason.  The other specs namely a bore of 8 mm and stroke of 16 mm which I have followed along with the 30 mm flywheel the only other dimension was 40 mm between the base of the engine and the center of the paddle axle.  By thinking was that the brass worm and wheel used was heavy and had too much friction for such a small engine.  The nylon gears I have use are light and have little friction the only problem being it was difficult to find large gears that would give a comparatively low gear reduction for a worm and wheel.  I won't be able to check out under load the gear box made until I return to the UK in a couple of weeks.
Regards Tony.
Offline Tony Bird
A drawing of the gear box attached; the idea is that an engine can be bolted to it using an extended bush as a registering point.  Any questions please ask.
Regards Tony.
Offline Tony Bird
I forgot the engine drawings which is for both single and double acting cylinders.  For  a single acting engine ignore the lower ports.
Regards Tony.
Offline Sekim
Thanks for the engine port details etc.  I'm sure I and others will use this in the future to advantage.
Regards  Mike
