Author Topic: Boiler sizes wanted for E T Westburys diagonal engine  (Read 4362 times)
chipenter
« on: July 03, 2015, 06:18:15 AM »
As my engine is getting near to running , I am looking for a boiler to go with it , it has no gaskets or seals yet , its 3/4" x 1 7/8" bore and stroke , any help aprsiated .
« Last Edit: July 03, 2015, 06:20:08 AM by chipenter »
Offline Brian Gates
Re: Boiler sizes wanted for E T Westburys diagonal engine
« Reply #1 on: July 03, 2015, 06:05:07 PM »
In 2005 there was an article by Ron Isted in Model Engineer on modelling PS Dartmouth Castle using this engine.  He refers to two articles in Model Engineer:
ME 2975, (1958/5/29) where a boiler is described by W. Melville specifically for the Westbury Engine.  If this is the same boiler that is still available from the plans service "Scotch Return Boiler M22" http://www.myhobbystore.co.uk/product/17408/scotch-return-boiler-m22 (and I think it must be, as it is the only boiler design of his that I can find in the Model Engineer index http://www.groundlevel.demon.co.uk/me_index.html ) the drum appears to be 6" x 6".
ME3527 (1975/12/19) where D. G. Gooden began a series of four articles on marine steam plants, beginning with a similar boiler with a drum of 3" x 3", but it is suggested in the Dartmouth Castle that this could be scaled up to 4 3/8".
Hope this helps
Brian
chipenter
« Reply #2 on: July 04, 2015, 05:35:00 AM »
Thank you Brian I have the mags as PDF files very usefull , I looked for ME index added your link to favorets .
