Author Topic: 2-Cylinder oscillating Steam Engine for smaller Paddlewheelers  (Read 5593 times)
Offline Gerhardvienna
http://www.paddleducks.co.uk/smf/index.php?action=downloads;sa=view;down=408
« Last Edit: December 22, 2014, 06:56:55 AM by Gerhardvienna »
Re: 2-Cylinder oscillating Steam Engine for smaller Paddlewheelers
« Reply #1 on: July 29, 2014, 05:09:29 AM »
A short closer explanation to the Engine
This engine has two oscillating cylinders, and works very similar to the original Penn-Engine. The stroke is 18mm and the bore 12 mm. The engine is reversible, the steam goes in and out the cylinders by the center bolts in the middle, and is distributed in the middle block. The crankshaft can be shortened from 100 mm down to around 90 mm.
Lathe and milling machine is required, clean and exactly work absoluteley necessary!
Best regards from Vienna
Gerhard
Offline bobmclean
« Reply #2 on: August 12, 2015, 10:25:15 AM »
Looks interesting. Ill print, translate and put it in the file for a future model
« Reply #3 on: May 24, 2016, 08:49:42 PM »
Hi Bob
Sorry for my late reply, was not in  here for a while! Hope it works well, this was my very first attempt of constructing such an engine. Have fun!!
Gerhard
