Author Topic: 90 mm Paddle wheels  (Read 4038 times)
solo
90 mm Paddle wheels
« on: August 24, 2013, 10:26:30 AM »
Hi
Is there anyone out there kind enough and able to craft me 4x90 mm paddle wheels. I have tried and tried to cut these out but to no avail.
I have attached a picture of the type very plain no fancy work.
If you are able to make them for me please pm me and let me know the cost.
Many thanks for reading.
Problem solved many thanks  to Barry for his help in this matter
« Last Edit: August 26, 2013, 07:47:09 PM by solo »
Offline bill stafford
Re: 90 mm Paddle wheels
« Reply #1 on: October 17, 2013, 05:20:07 PM »
g day solo,
if you contact a laser cutter , business, they will cut out anything , for a price $$
you need to be careful of weight, don't use brass+you can bolt on the float w stainless 2 mm bolts , bent to form "J" bolts .
i have done this for a adelaide set of p wheels , now i tend to get float a boat HIPS kits , have you tried brewer for a set ??
im sorry i dont have spare time to build them for you , good luck
regards bill s
