Author Topic: MicrocosmM7 Steam Engine part Sight Level Displacement Lubricator 1/4"-40 Engin  (Read 5607 times)
dlyyld
MicrocosmM7  Steam Engine part Sight Level Displacement Lubricator 1/4"-40 Engine
This is a displacement oiler for a model steam engine.
Screw fitting is 1/4" X 40 TPI. Length 70mm, width 35MM, diameter 16MM. Solid brass.Quartz glass wall thickness of 2 mm.
Guys.........for the past few months....... :whistle ...I have had the pleasure of communicating with Jin....the principal of MICROCOSM in China
His work & devotion to model steam deserves  :clap ....& which ultimately will allow more affordable steam components to be in the reach of more members
Thankyou Jin......... :beer
______________________________________________________________________________________________________________________________________________
From: Derek Warner [mailto:dlwarner@bigpond.net.au]
Sent: Friday, 26 April 2013 4:12 PM
To: Microcosm Model Steam 163413fc (163413fc@163.com)
Subject: Microcosm Lubricator with Glass Tube Lens 26.04.2013
Jin….I agree….people need to see how much oil is left or how much water needs to be drained out……….as a concept, this is very important for me
•   This is a good cost effective solution….same style & design…..just a CNC milled double sided slot + 2 sealing o-rings & a glass tube
•   Would you position the o-rings as radial or longitudinal compression? ….radial is technically a better solution
•   Maybe this should be your standard glass tubed lubricator from now on?
•   Some people prefer a fixed orifice to meter the steam oil displacement over an externally adjustable facility
•   Some people say the fixed orifice wastes oil……….
•   I am one of the people that would rather have too much steam oil in my engine than not enough
•   I am happy with the fixed orifice concept until I know better
Sent: Friday, 26 April 2013 3:20 PM
To: Derek Warner
Subject: Re:Other Steam components 26.04.2013
Derek,
Yes,
My quartz glass tube lubricators 16X65MM with regulator and I think someone would need.
Jin
