Author Topic: Annealing brass  (Read 5300 times)
sinjon
Annealing brass
« on: April 21, 2012, 12:01:14 AM »
I have just started to make a pair of paddle wheels from brass. (my first paddle boat)
I am using 1/8'' square brass and I am 'trying' to form a circle of 110mm (4 3/8'') I can see that it is going to be exceedingly difficult unless I can anneal the brass.
Can anyone give me a clue as to how to do this.
Thanks
Colin
Re: Annealing brass
« Reply #1 on: April 21, 2012, 02:40:35 AM »
Hi PD's...... :41 ....sorry sinjon
1. Don't believe Google
2. First method is to heat brass to cherry red then quench in cold water  :c002...this is incorrect
3. Correct method is to heat brass to cherry red then let cool at ambient temperature
4. I see your project as  :hammer difficult to achieve.......[been there done that type thing]
5. Talk to Kim @ ......???????? Clyde Model Boats.....he does brilliant scale feathering wheels.........
I will correct the name after I have a  :beer .....or two.......Derek.......no not needed.......
« Last Edit: April 21, 2012, 02:43:45 AM by derekwarner_decoy »
Re: Annealing brass
« Reply #2 on: April 21, 2012, 11:20:20 AM »
My experience is that you can Quench in water, but you get more distortion that air cooling.
Re: Annealing brass
« Reply #3 on: April 21, 2012, 05:33:50 PM »
Quenching in will do nothing except save time.
To bend a perfect circle you will need a former slightly smaller than the finished item. A length of brass at least 6 inches longer than the circumference. as the ends will not bend as well as the middle.R.G.Y
sinjon
Re: Annealing brass
« Reply #4 on: April 21, 2012, 05:41:42 PM »
Enough there to get me started - Thanks
Colin
