Author Topic: Boiler controls  (Read 3793 times)
brian freegard
Boiler controls
« on: January 23, 2012, 02:23:58 AM »
Hello All,
I'm looking for an electonic water level control for a model size boiler. I have Malcolm Beak's circuit but the Ferranti I.C. s are now unobtainable. I also have a schematic from somewhere titled ' Boiler control Catherine Ann', but no other details. Has anyone any units which use currently available componenents- preferrably tried and tested?
Thanks,
Brian Freegard
Offline peter ravenscroft
Re: Boiler controls
« Reply #1 on: January 24, 2012, 01:43:31 AM »
have alook in the last 2 issues of model engineer there is an article on what you require
 the last on will still be available till friday
peter
Offline malcolmbeak
Re: Boiler controls
« Reply #2 on: January 24, 2012, 07:02:03 AM »
Hi Peter
If you really want to make the control unit to my old design, I still have several of the 556 ICs if you would like a couple.
Malcolm
Re: Boiler controls
« Reply #3 on: January 25, 2012, 12:48:52 AM »
thanks malcombe for the offer i have a number of chips to play with
i also have the river queen drawings and your engine drawing but at the moment i trying to finish a 3 1/2 gauge Darjeeling loco and if i stop it will take me ages to start again
peter
brian freegard
Re: Boiler controls
« Reply #4 on: January 25, 2012, 07:06:40 AM »
Thanks Peter and Malcolm.
I have ordered the MEs from my newsagent so I will have a look at Martin's design.
I have done a bit more research into my original schematic. It apparently was published in Model Boats. Don't know when and a search on the MB website has drawn a blank. I probably have enough to reproduce the circuit but I would really like some feedback as to how good it is before I start.
brian freegard
Re: Boiler controls
« Reply #5 on: January 26, 2012, 07:00:33 AM »
Back again!
I have a copy of the current ME now but since Martin Ransen admits to his designs being quite old and not properly proven I will go with Malcolm Beak's unit. Thanks Malcolm.
The Ferranti ICs that I was thinking of were not used in your design after all. 556 devices are stock items at Maplins as are the NPN transistor equivalents.  I was really looking to drive an electric pump and will probably take the easy way out and use a servo to operate a switch or relay.
Happy boating
Brian
