Author Topic: A Paddle tug in Oregon  (Read 37687 times)
Re: A Paddle tug in Oregon
« Reply #15 on: January 24, 2012, 09:15:22 PM »
Oh dear PD's........it is good that we can post without fear of  :breakcomp
mogogear.... that PURPLE stained wood is very bright
edited by dw 28/01/2012 ..........Derek :beer
« Last Edit: January 28, 2012, 08:03:04 AM by derekwarner_decoy »
mogogear
« Reply #16 on: January 25, 2012, 03:09:09 AM »
No worries Derek..I didn't stain it - it is the natural color of the wood and I think when you see it after it is darkened by varnish it will deepen  and the color should be easier on your eyes....... :kiss1
mogogear
« Reply #17 on: January 27, 2012, 05:01:00 PM »
DEREK,
Does this put your mind at ease :goodnews The purple wood now is stained with mahogany stain and a coat of polyurethane
New bands and mounted on the plate- Lots of superstructure work about to be to photo stage
Ta
« Reply #18 on: January 27, 2012, 10:04:38 PM »
Oh dear PD's ...what have I said  :shoot :sobbing ......... :sorry mo.............
edited by dw......28/01/2012............................Derek
« Last Edit: January 28, 2012, 08:01:26 AM by derekwarner_decoy »
« Reply #19 on: January 28, 2012, 12:25:49 AM »
Hi Greg,
I think Derek must be standing on his head or suffering from celebrating Australia Day.
I think it looks fine.
mogogear
« Reply #20 on: January 28, 2012, 12:26:47 PM »
My dear Derek- No offense was taken on this end- I have thicker skin that that - you and the others are most helpful and supportive.
The goofy hobby shop near by failed to have mahogany- but had exotic stuff?? I found that amusing
I just needed hard wood in strips the size I wanted!
Here is a quick mock up of the exhaust piping I am adding
Port holes coming soon and some roofing
« Reply #21 on: January 28, 2012, 06:58:05 PM »
Sounds like my local model shop keeper, i don't think he can pronounce expensive and uses exotic in it's place ...
I had a quick look at your web site this morning very interesting! ...
Look forward to reading more.
Offline Spankbucket
  • Emigre from South London
« Reply #22 on: January 28, 2012, 08:32:59 PM »
I bought some sheets of walnut recently and talk about exotic......they carry a 'made in China' label!!!
« Reply #23 on: January 28, 2012, 10:11:27 PM »
Hi PD's.....  :whistle .....& just to get back on the original build thread.......
mo...... have you considered the required breathing for the gas fired boiler? :darn
I see the open door just AFT of the paddle box & a few MOUTHED vents facing FWD...& the mesh horizontal plates AFT of the chimney stack
Will this provide an adaquate air draft for the boiler? .....  :goodluck ...... Derek
mogogear
« Reply #24 on: January 29, 2012, 03:24:30 AM »
Great question Derek,
Shooting from the hip... :thinking ..........  I think I do.
The two rear grated openings are 2" x 1"
Two doors are 2" x 1"
Two side clerestory openings made from ladder stock emulating louvered openings
each .75" x 4"
That feels sufficient...???
« Reply #25 on: January 29, 2012, 08:18:46 AM »
Talking with a few mates... :gathering ...over a few :beer about heat transfer
Like most things in life containing a lot of hot air  :hehe ...heat will build up & it's no good & won't go away unless you can move it
May be worth considering a low voltage computer fan to draw in air to create a pressure difference & thus expelling the hot air........however placement is critical to obtain the draft or air flow.....
Two methods here  :crash
1. use the fan to create a higher pressure = push the hot air out
2. use the fan fo create a lower pressure = suck the hot air out
May sound  crazy..... :ranting, but either will work.............Derek
mogogear
« Reply #26 on: January 29, 2012, 05:28:07 PM »
Good points.... Fan noted...should be easy  to run off batteries for lights..
.Hmmmmmm, I should be able to find a small one
mogogear
« Reply #27 on: February 13, 2012, 12:10:13 PM »
Last thought on the fan while I shop for a small low speed DC model   - I should use it to draw cool air in so it does not sit in hot air the whole time-
I knocked out a quick condenser and have been collecting fittings , valves , attenuators and many little fiddly bits pepping for the plumbing session with the boiler, pump, attenuator , gas supply line and the engine.
Here is my condenser -What it was - label stripped off-  and what it ended up like-
 Yep tin can- yep it may rust our some day..but at a cost of about $2 for some brass sheet cut in to bands and a few brass nuts and screws- the price is right. I think oily gunky water may give it a decent life of a few years
« Reply #28 on: February 13, 2012, 04:16:40 PM »
Hi PD's..... :whistle ...I think we would all agree that Mo has turned an elephants ear into a silk purse  :s_cool  ...& that's just what it will do....cool that steam
Nearly as adventive as our UK colleague RGY  :tongue1 .......keep up the good work....Derek :beer
« Reply #29 on: February 13, 2012, 06:38:52 PM »
I  looked at the photo and thought the label on the can said Orgasmic Tomato Paste - I really Must take more water with it!
« Last Edit: February 13, 2012, 06:42:08 PM by Eddy Matthews »
