Author Topic: hello  (Read 2089 times)
sandgrounder
hello
« on: October 19, 2011, 04:02:43 AM »
hi ,i am new here , and hoping to learn ..i recently got running a pintail launch for a nephew .  and thought i would like to have a go at a  launch with a steam powered motor
  still not sure about any of that ,   but i have a copper kit to build a boiler (vertical ) ,  and would like a design or the optimum sizes fora boiler ..the diameter is 63 mm .  but i am not sure on the length the boiler tank should be
i aim the fit cross tubes and maybe hedgehog  pins to give heat
   i do not want to go to great expense .. so aiming for a spirit type burner of some sort  .
i would like to have a twin cylinder engine of some type   and would like a good kit to build as i have no real access to machinery .
  so it needs to be machined ready .
   also i would like to know the best thread sizes and feed pipe sizes
    regards sandgrounder
mogogear
Re: hello
« Reply #1 on: October 19, 2011, 01:52:42 PM »
Welcome to you!!!!! Maybe a few details on how big a launch you plan on and if you have a type of engine in mind....lime a twin or single, reversing capable or not etc..
That will help determine your steam supply needs , then some can chime in with a size recommendation !!
Once again
Glad to have you about
sandgrounder
Re: hello
« Reply #2 on: October 20, 2011, 06:24:24 AM »
thanks
 i missed that totally, the launch ,or vessel would need to be about 24 =26 inches long due to space for storage
  and the engine i thought of was the GAGE TVR1A
http://www.grahamind.com/tvr1a.html
