Author Topic: Choice of boiler fittings  (Read 6047 times)
phoenix01
« on: January 14, 2011, 07:14:46 AM »
What boiler fittings to buy?
As a new member this is my first proper post so I hope that I am using the right protocol.
I have a 4" horizontal marine boiler kit to build and am in the process of sliding up the very steep learning curve. The aim is for a smart installation and I would welcome any thoughts on the choice of boiler fittings (preferably from UK suppliers) - safety valve, globe valve, check valve & level gauge. What makes a good or bad fitting. Is price any guide to quality.
BTW I do intend to consult a boiler certifier before starting construction, but I need to make the bushes first to complete the set of parts.
Thanks, James
Re: Choice of boiler fittings
« Reply #1 on: January 20, 2011, 02:14:37 AM »
Are you planning to use metric or imperial threads?
phoenix01
« Reply #2 on: January 24, 2011, 03:15:28 AM »
Hello kno3, thanks for your reply. I will be using imperial ME threads. James
« Reply #3 on: January 24, 2011, 09:13:36 AM »
There are many suppliers in Britain. I have used fittings from:
http://www.ajreeves.com/ Click on shop and boiler fittings
There is also http://www.steamfittings.co.uk/ and others.
phoenix01
« Reply #4 on: January 26, 2011, 04:37:36 AM »
Many thanks. There is quite a variation in price, e.g. Reeves seem to be the most expensive. Is there a significant difference over the less expensive offerings. For example will the stem screw out of a cheap steam valve?
« Reply #5 on: January 26, 2011, 08:28:24 AM »
Hi PD's......phoenix01
With your standard unions etc....you get what you get get....a body + nut + solder cone ....& irrespective of the brand of manufacture
However some steam valves are designed as a metering/isolation valve & have preferred direction of flow to ensure that the metering is carried out in the designed manner [all to do with the flow of steam over the needle & the height of the inlet & outlet galleries within the valve body
The valve on the left was sold as 1/8" full bore, but has no direction markings......
The valve on the right [althought much smaller] was also sold as 1/8" full bore....but it does have a direction arrow...I suspect it is a Reeves globe valve #39/7061...I can see the same direction arrow stamping in the body
In our imperfect world....we model steam boaters are generally using these valves as isolation valves & not as controlable metering valves...... :whistle ....so maybe it is not necessary.....
The valve to the left requires undue force to make steam tight :ranting
The valve to the right required light thumb & forefinger force to make steam tight  :trophy
I have taken the valve on the left apart...there is no mark on the needle......I cannot see the corresponding seat area inside, however have lapped the needle to the seat with lapping paste to no avail :41
I would not purchase another el-cheapo metering/isolation valve such as this again .....Derek
PS1...I purchased the smaller steam valves [a pair] in Australia....but the design & handwheel look very similar to the Reeves variety.....#39/7061
« Last Edit: January 26, 2011, 09:05:33 AM by derekwarner_decoy »
phoenix01
« Reply #6 on: January 27, 2011, 05:23:28 AM »
Hi Derek. There had to be a reason for the substantial difference in price. Your experience is very helpful. Thanks very much. James
