Author Topic: Help with Steam Engine Comparisons  (Read 7916 times)
sunworksco
« on: November 21, 2010, 06:02:44 AM »
I am interested in buying a steam engine and was wondering about these two engines.
, Stuart triple Expansion and Saito 3DTR Triple.
Can anyone tell me about the build comparisons, HP at the flywheel and pros/cons?
Thanks,
Giovanni
Re: Help with Steam Engine Comparisons
« Reply #1 on: November 22, 2010, 09:14:54 AM »
They are very different beasts. The Saito is much smaller and all 3 cylinders receive steam directly. The Stuart is much bigger and a compound (steam gets into the smallest cylinder, from there into the middle one and then in the largest).
You can buy the Saito ready-to-run from the manufacturer, but I don't think you can get the Stuart ready-to-run, only as castings.
sunworksco
« Reply #2 on: November 22, 2010, 09:34:40 AM »
You are right, only offered as an unmachined castings kit.
I do not understand how the price for the kit is so expensive.
I could understand if it was an unassembled machined kit, machined from 316L stainless-steel and silicon/bronze but not cast iron and steel.
Someone convince me why it is worth : Price: £584.00 (exc VAT)
Thanks,
Giovanni
« Last Edit: November 22, 2010, 09:52:13 AM by sunworksco »
« Reply #3 on: November 22, 2010, 10:46:08 PM »
Perhaps I should also add that I do not consider the Stuart triple expansion compound engine to be suitable for normal sized model boats (up to one meter). It is a very large engine.
The price for the castings is indeed very high. I guess it is a very individual decision if it is worth or not. Stuart engines have a sort of cult status which explains their high prices. If I were to build such an engine (and I'm not saying I actually can), I would probably do it from scratch and save the money for the castings  ;D
« Reply #4 on: November 23, 2010, 12:46:01 AM »
I just looked and you can buy the Drawings,
95145 Stuart Tripe Drawings (3 drawings) £28.50
Then you can make them out of whatever you want.
Personally I wouldn't use anything larger that a D10 in a model boat unless I was going to be riding in it.
sunworksco
« Reply #5 on: November 23, 2010, 09:06:15 AM »
I am building an amphibious vehicle with helical screw drives, with a Stuart Triple on each screw.
It will have a Jules Verne design style.
It can be used as a snow-mobile, too. It will be 60' OAL and will pull a sled behind it.
Thanks,
Giovanni
http://www.youtube.com/watch?v=zBjlSJf4274
http://www.youtube.com/watch?v=afJ18eJeNgU&feature=related
« Reply #6 on: November 24, 2010, 07:07:43 AM »
how about something like this????
http://www.youtube.com/watch?v=irp004zw8pQ&feature=related - but with the 'pontoons' with screws like in those pictures....
sunworksco
« Reply #7 on: November 24, 2010, 08:14:06 AM »
I would like to use a MaccSteam horizontal boiler with two Part No: 34-50-71382 Stuart Twin Launch Unmachined Sets.
The vehicle will pull a sled/wagon for a person to ride on.
Here is the Stuart Compound Steam Engine build : http://compound.modelengines.info/index.html
Thanks,
Giovanni
