Author Topic: Nautical expressions  (Read 3810 times)
« on: August 05, 2010, 04:35:03 PM »
Just to keep you amused, here's a list of the most common expressions that stem from a nautical background, many of them are still in common usage today - How many did you know?
As the Crow Flies
When lost or unsure of their position in coastal waters, ships would release a caged crow. The crow would fly straight towards the nearest land thus giving the vessel some sort of a navigational fix. The tallest lookout platform on a ship came to be know as the crow's nest.
Leeway
The weather side of a ship is the side from which the wind is blowing. The Lee side is the side of the ship sheltered from the wind. A lee shore is a shore that is downwind of a ship. If a ship does not have enough "leeway" it is in danger of being driven onto the shore.
Windfall
A sudden unexpected rush of wind from a mountainous shore which allowed a ship more leeway.
Over the Barrel
The most common method of punishment aboard ship was flogging. The unfortunate sailor was tied to a grating, a mast or over the barrel of a deck cannon.
To Know the Ropes
There was miles and miles of cordage in the rigging of a square rigged ship. The only way of keeping track of and knowing the function of all of these lines was to know where they were located. It took an experienced seaman to know the ropes.
Dressing Down
Thin and worn sails were often treated with oil or wax to renew their effectiveness. This was called "dressing down".   An officer or sailor who was reprimanded or scolded received a dressing down.
Footloose
The bottom portion of a sail is called the foot. If it is not secured, it is footloose and it dances randomly in the wind.
Booby Hatch
Aboard ship, a booby hatch is a sliding cover or hatch that must be pushed away to allow access or passage.
First Rate
Implies excellence. From the 16th century on until steam powered ships took over, british naval ships were rated as to the number of heavy cannon they carried. A ship of 100 or more guns was a First Rate line-of-battle ship. Second rates carried 90 to 98 guns; Third Rates, 64 to 89 guns; Fourth Rates, 50 to 60 guns. Frigates carrying 48 to 20 guns were fifth and sixth rated.
Pipe Down
Means stop talking and be quiet. The Pipe Down was the last signal from the Bosun's pipe each day which meant "lights out" and "silence".
Chock-a-Block
Meaning something is filled to capacity or over loaded. If two blocks of rigging tackle were so hard together they couldn't be tightened further, it was said they were "Chock-a-Block".
Groggy
In 1740, British Admiral Vernon (whose nickname was "Old Grogram" for the cloak of grogram which he wore) ordered that the sailors' daily ration of rum be diluted with water. The men called the mixture "grog". A sailor who drank too much grog was "groggy".
Three Sheets to the Wind
A sheet is a rope line which controls the tension on the downwind side of a square sail. If, on a three masted fully rigged ship, the sheets of the three lower course sails are loose, the sails will flap and flutter and are said to be "in the wind". A ship in this condition would stagger and wander aimlessly downwind.
Pooped
The poop is the stern section of a ship. To be pooped is to be swamped by a high, following sea.
Buoyed Up
Using a buoy to raise the bight of an anchor cable to prevent it from chafing on a rough bottom.
By and Large
Currently means in all cases or in any case. From the nautical: by meaning into the wind and large meaning with the wind: as in, "By and Large the ship handled very well."
Cut and Run
If a captain of a smaller ship encountered a larger enemy vessel, he might decide that discretion is the better part of valor, and so he would order the crew to cut the lashings on all the sails and run away before the wind. Other sources indicate "Cut and Run" meant to cut the anchor cable and sail off in a hurry.
In the Offing
Currently means something is about to happen, as in - "There is a reorganization in the offing."    From the 16th century usage meaning a good distance from shore, barely visible from land, as in - "We sighted a ship in the offing."
Skyscraper
A small triangular sail set above the skysail in order to maximize effect in a light wind.
The Bitter End
The end of an anchor cable is fastened to the bitts at the ship's bow. If all of the anchor cable has been payed out you have come to the bitter end.
Toe the Line
When called to line up at attention, the ship's crew would form up with their toes touching a seam in the deck planking.
Back and Fill
A technique of tacking when the tide is with the ship but the wind is against it.
Overhaul
To prevent the buntline ropes from chaffing the sails, crew were sent aloft to haul them over the sails. This was called overhauling.
Slush Fund
A slushy slurry of fat was obtained by boiling or scraping the empty salted meat storage barrels. This stuff called "slush" was often sold ashore by the ship's cook for the benefit of himself or the crew. The money so derived became known as a slush fund.
Bear Down
To sail downwind rapidly towards another ship or landmark.
Under the Weather
If a crewman is standing watch on the weather side of the bow, he will be subject to the constant beating of the sea and the ocean spray. He will be under the weather.
Overreach
If a ship holds a tack course too long, it has overreached its turning point and the distance it must travel to reach it's next tack point is increased.
Gone By the Board
Anything seen to have gone overboard or spotted floating past the ship (by the board) was considered lost at sea.
Above Board
Anything on or above the open deck. If something is open and in plain view, it is above board.
Overwhelm
Old English for capsize or founder.
Between the Devil and the Deep Blue Sea
The devil seam was the curved seam in the deck planking closest to the side of the ship and next to the scupper gutters. If a sailor slipped on the deck, he could find himself between the devil and the deep blue sea.
The Devil to Pay
To pay the deck seams meant to seal them with tar. The devil seam was the most difficult to pay because it was curved and intersected with the straight deck planking. Some sources define the "devil" as the below-the-waterline-seam between the keel and the the adjoining planking. Paying the Devil was considered to be a most difficult and unpleasant task.
Rummage Sale
From the French "arrimage" meaning ship's cargo. Damaged cargo was sold at a rummage sale.
A Square Meal
In good weather, crews' mess was a warm meal served on square wooden platters.
Son of a Gun
When in port, and with the crew restricted to the ship for any extended period of time, wives and ladies of easy virtue often were allowed to live aboard along with the crew. Infrequently, but not uncommonly, children were born aboard, and a convenient place for this was between guns on the gun deck. If the child's father was unknown, they were entered in the ship's log as "son of a gun".
Let the Cat Out of the Bag
In the Royal Navy the punishment prescribed for most serious crimes was flogging. This was administered by the Bosun's Mate using a whip called a cat o' nine tails. The "cat" was kept in a leather or baize bag. It was considered bad news indeed when the cat was let out of the bag.    Other sources attribute the expression to the old english market scam of selling someone a pig in a poke(bag) when the pig turned out to be a cat instead.
Overbearing
To sail downwind directly at another ship thus "stealing" or diverting the wind from his sails.
No Room to Swing a Cat
The entire ship's company was required to witness flogging at close hand. The crew might crowd around so that the Bosun's Mate might not have enough room to swing his cat o' nine tails.
Taking the wind out of his sails
Sailing in a manner so as to steal or divert wind from another ship's sails.
Start Over with a Clean Slate
A slate tablet was kept near the helm on which the watch keeper would record the speeds, distances, headings and tacks during the watch. If there were no problems during the watch, the slate would be wiped clean so that the new watch could start over with a clean slate.
Taken Aback
A dangerous situation where the wind is on the wrong side of the sails pressing them back against the mast and forcing the ship astern. Most often this was caused by an inattentive helmsman who had allowed the ship to head up into the wind.
At Loggerheads
An iron ball attached to a long handle was a loggerhead. When heated it was used to seal the pitch in deck seams. It was sometimes a handy weapon for quarrelling crewmen.
Fly-by-Night
A large sail used only for sailing downwind and requiring rather little attention.
No Great Shakes
When casks became empty they were "shaken" (taken apart) so the pieces, called shakes, could be stored in a small space. Shakes had very little value.
Give (someone) a Wide Berth
To anchor a ship far enough away from another ship so that they did not hit each other when they swung with the wind or tide.
Cut of His Jib
Warships many times had their foresails or jib sails cut thinly so that they could maintain point and not be blown off course. Upon sighting thin foresails on a distant ship a captain might not like the cut of his jib and would then have an opportunity to escape.
Garbled
Garbling was the prohibited practice of mixing rubbish with the cargo. A distorted, mixed up message was said to be garbled.
Press Into Service
The British navy filled their ships' crew quotas by kidnapping men off the streets and forcing them into service. This was called Impressment and was done by Press Gangs.
Touch and Go
This referred to a ship's keel touching the bottom and getting right off again.
Scuttlebutt
A butt was a barrel. Scuttle meant to chop a hole in something. The scuttlebutt was a water barrel with a hole cut into it so that sailors could reach in and dip out drinking water. The scuttlebutt was the place where the ship's gossip was exchanged.
Clean Bill of Health
This widely used term has its origins in the document issued to a ship showing that the port it sailed from suffered from no epidemic or infection at the time of departure.
Coxswain
A coxswain or cockswain was at first the swain (boy servant) in charge of the small cock or cockboat that was kept aboard for the ship's captain and which was used to row him to and from the ship. The term has been in use in England dating back to at least 1463. With the passing of time the coxswain became the helmsman of any boat, regardless of size.
Mayday
The distress call for voice radio, for vessels and people in serious trouble at sea. The term was made official by an international telecommunications conference in 1948, and is an anglicizing of the French "m'aidez," (help me).
Shows his true colors
Early warships often carried flags from many nations on board in order to elude or deceive the enemy. The rules of civilized warfare called for all ships to hoist their true national ensigns before firing a shot. Someone who finally "shows his true colors" is acting like a man-of-war which hailed another ship flying one flag, but then hoisted their own when they got in firing range.
« Last Edit: August 05, 2010, 09:34:47 PM by Eddy Matthews »
Offline Roderick Smith
Re: Nautical expressions
« Reply #1 on: August 05, 2010, 05:19:04 PM »
I've never quite worked out how nautical the river is: AFAIK right & left sit quite happily with starboard & port.
Beam and draft are in.
Freeboard is in, but not needed very often.
The term 'head' is never used.
Galley and kitchen are about equal.
AFAIK For'ard never appears (perhaps front or bow); stern is preferred to aft.
On a different tack:
Avast behind: See http://goodnightspilsby.blogspot.com/2007/08/not-that-this-blog-is-sizist-but_14.html
And all the ribald versions of Captain Pugwash (eg Roger the cabin boy).
'Quick, throw the lockmaster a line'.
'Who was that lady I saw you with last night?'
Roderick B Smith
Rail News Victoria Editor
old man
« Reply #2 on: August 05, 2010, 07:12:42 PM »
Very informative Eddy, being a west country lad and descendent of somewhat dubious seafaring folk I was aware of most of the expressions but please where can I find more? And is "shiver-me-timbers" pure hollywood or something to do with cleanig or repairing the deck.
                                       Thanks For The Best Forum Site Ever
                                               oldman
« Reply #3 on: August 06, 2010, 05:35:36 AM »
some here - including 'shiver me timbers! -http://www.phrases.org.uk/meanings/nautical-phrases.html
« Last Edit: August 06, 2010, 05:39:01 AM by mjt60a »
Offline djcf
« Reply #4 on: August 06, 2010, 06:56:42 AM »
I wonder how many of those sayings you could get in the one sentence ;D :-X
