Other Marine Models
Live steam
An oscillating overhead-crankshaft engine for a paddlewheeler.
Topic: An oscillating overhead-crankshaft engine for a paddlewheeler. (Read 14868 times)
kno3
November 13, 2009, 12:44:03 AM »
Hi!
I have recently acquired an oscillating steam engine and boiler. It is made after plans by Basil Harley, for the Miranda steam launch. That's what it looked like when I got it, ready to be put to good use in a propeller driven launch:
But I had other plans with it
It just happens that this engine can easily be turned into a overhead crankshaft oscillator, which would be perfect for a paddle-wheeler. So I started disassembling and rearranging parts:
Here's the result of just changing the position of the parts, no modification whatsoever involved:
In my opinion it now looks realistic and quite close to the real-life oscillating engines that power paddle-wheel ships from the 1870'ies and 1880'ies, found even today on European rivers (Elbe, Danube etc.).
steamboatmodel
Re: An oscillating overhead-crankshaft engine for a paddlewheeler.
November 13, 2009, 05:00:46 AM »
That is fantastic. Thank you for figuring it out.
You now have us all hitting our heads saying "now why didn't I think of that!"
Basil Harley would have been very impressed. Now where did I put those magazines with the Miranda build in them.
Hankwilliams
November 13, 2009, 08:49:03 PM »
Very well in construction an even optical! Looks exactly like the engines of the older Elbe paddlers.
Congratulations!
kno3
November 13, 2009, 11:06:07 PM »
Thanks!
I think I'm going to paint the cylinders black and keep the rest shiny brass and the upper and lower frames dark green, to be closer to the originals.
Misterbee
Junior Member
November 14, 2009, 01:01:04 AM »
Well done kno3. You have stumbled on the Aussie version, which is upside down for the southern hemisphere of course.
Cheers.
Misterbee.
kno3
November 14, 2009, 01:34:58 AM »
You mean you've been doing this all along?
kno3
November 28, 2009, 10:52:47 PM »
Hi all,
here the next step in converting this oscillator in a paddle-wheeler engine. I've disassembled it completely for refurbishment, doing the following (sorry, forgot to take pictures of all stages):
1. Cleaning old paint from cylinders, then blackening them chemically.
2. Changing old worn piston rings with Teflon.
(no pictures)
3. Painting the crankshaft bearings and base.
4. Cutting 7 BA hex head screws to size, to replace all slotted head screws previously used for the cylinders and crankshaft. I had to keep the fine slotted screws for the piston rod connection to the crankshaft, as the were countersunk, so no way of putting hex head there. Adding some feet (4 BA screws) to clear the bottom of the cylinders.
kno3
November 28, 2009, 11:12:22 PM »
Here's a short video of the engine run on air:
http://www.youtube.com/watch?v=TqUhyPwO-9Y
November 28, 2009, 11:45:20 PM »
well PD's........may only be 5 seconds......but well done kno3
....Derek
gyula
Newbie
Reply #9 on:
December 28, 2009, 08:00:42 AM »
Nice work...
Hope we shall see it soon in something like this:
http://www.youtube.com/watch?v=cvu-FmEXy2I
kno3
Reply #10 on:
December 28, 2009, 10:28:01 AM »
That was my inspiration!
abcdale
Reply #11 on:
May 15, 2010, 08:37:47 AM »
nice job ... I have this engine in my miranda ,(but not upside down) you mention teflon rings??? mine appeatr to have cotton in my rings would that be correct? ... you can probably guess , I can,t get mine to work at the moment .... and I have million questions
Reply #12 on:
May 15, 2010, 03:51:26 PM »
Hi PD's....welcome abcdale........is the suspect piston ring hemp/cotton twine
grey
in colour?...if so it could be a braided graphite impregnated material.......just like the old James Walker steam gland packing material......
This type of packing is fine for steam use, however in static applications [gland] but not designed for dynamic [piston] applications
....having said this....it will work on low pressure & low temperature steam engines as the steam oil lubrication stops the hemp/cotton material from drying out ....Derek
Last Edit: May 16, 2010, 09:09:59 AM by derekwarner_decoy
kno3
Reply #13 on:
May 16, 2010, 02:24:28 AM »
abcdale: Originally there was some sort of cotton/hemp or so in the piston groove, which I have discarded and replaced with Teflon tape.
It's really easy to do, just twist the Teflon tape until you get a string and wind a suitable length tightly in the piston groove, then roll it on a wooden surface to press it in a bit, so it fits the cylinder. Worked really well for me in several engines.
You could also use nitrile or viton o-rings, if you find a suitable size.
Other Marine Models
Live steam
