Author Topic: Warrier MKII Steam Engine - Vanished Posting by Kiwi....Ian...  (Read 4276 times)
« on: November 02, 2009, 08:36:12 PM »
Hi PD's....very strange.......I just read a posting from Kiwi...about an eBay win..........Warrier MKII A frame steam engine.........went to respond but it has disappeared ????????????
___________________________________________________________________________________________________________________________________________________________________
Designer: J P Bertinat
Star Rating:
A modified and improved version of Edgar T Westburys twin cylinder double-acting steam engine (M7) with 3/4in bore cylinders and 3/4in stroke. (Vols.146-147).
Sheet 1 General arrangement on non-reversing engine.
Sheet 2 Cylinder and end covers; piston, piston rods and crossheads; valve chest and covers, slide valves and valve rods, cylinder standard.
Sheet 3 Baseplate, crankshaft and bearings, connecting rod, eccentric rod, strap and sleeve, flywheel.
Sheet 4 Boiler feed pump assembly and details.
Sheet 5 Steam inlet manifold, inlet connector, exhaust manifold, exhaust tee, union and nipple.
Sheet 6 Arrangement and assembly of reversing gear.
Sheet 7 Reversing gear details, special components for single cylinder engine.
Complete set of 7 sheets.
Re: Warrier MKII Steam Engine - Vanished Posting by Kiwi....Ian...
« Reply #1 on: November 02, 2009, 09:30:17 PM »
Sorry....I responded to the wrong WEB site..........senior Warner moment  :beer.....Derek
Red_Hamish
« Reply #2 on: November 03, 2009, 06:58:07 AM »
Aye Derek, it goes to show that we are all susceptible to a senior moment now and then  :whistle Remember to remember where you last postedabout the last post  ;)
Jim
« Reply #3 on: November 03, 2009, 08:23:07 PM »
Derek you are a worry  ;D if you are this bad at sixty Lord help us when you turn eighty! Do you think the problem might be the culmulative effects of too much of what you Australians call Ale?? :beer
« Reply #4 on: November 03, 2009, 09:16:06 PM »
YES........................ :nahnah but :shhh.....I call it humble moderation..........  :hehe......Derek
