Author Topic: ANDREAS Steam ENGINE  (Read 3331 times)
Offline Steam Water
  • Rapid Fire Steam Machine
« on: October 30, 2009, 02:12:38 PM »
Hi all
      Has anybody tried the ANDREAS steam engine made by Hielscher. This engine seems to be able to power a boat
      up to 26" long. I am thinking of purchasing it with maching boiler and using it in the wood kit Louise by
      CONSTRUCTO
                   web site www.ministeam.com/acatalog/Hielscher.html
                                      THANKS, TERRY
Re: ANDREAS Steam ENGINE
« Reply #1 on: October 30, 2009, 11:00:11 PM »
Hi Terry,
I`ve used the ministeam engine in two small paddlewheelers - "Rigi"  lenght 82 cm, and "Hjeilen" of about the same dimensions (both Billing Boat Kits of the sixties).
The small engine is very compact and of light weight. With the gear reduction of 1 : 11 she is surprisingly powerful, the speed of the boats is much faster than scale. In connection with a small flame tube boiler (diameter 50 mm, lenght 120 mm) you will get a good propulsion.
Of course througt the light an thin materials the engine seems a little bit fragile compared with the normal brass made engines, but for small models like the Louise it will be the right choice.
Offline Steam Water
« Reply #2 on: October 31, 2009, 08:55:47 AM »
   Thanks Thomas for the info. I am also going to use it in to other models about the same length but have been
   away for wile and I did :) :) not find an info. on this engine.
                                               Terry
