Author Topic: Paddlewheels  (Read 36120 times)
Re: Paddlewheels
« Reply #30 on: September 19, 2009, 05:45:53 AM »
Hi All
Ok, more research = more questions
How would people feel if the wheel set were held together with nylon/ plastic nuts and bolts rather than metal / brass nuts and bolts? (assuming they would be of similar / identical size as their metal counterparts)
My reasons for asking -
1. They would be lighter ?
2. Graupner sell many with plastic rivets and have few complaints????? Nuts and bolts are a more permanent / robust fixing and possibly more scale?
3.Once painted how knows anyway?
Would really appreciate any and all feedback on this question.
Many thanks,
Re: Paddlewheels
« Reply #31 on: September 19, 2009, 05:57:50 AM »
hmmm, I'm not sure about plastic nuts and bolts Kim....
Can you get them small enough? I've never seen any below about 4mm diameter.
The threads are generally a very coarse pitch and therefore the nuts are much thicker than metal ones.
Lastly they break easily if your a bit too enthusuastic when tightening them.
So apart from a saving in weight (which would be marginal), and perhaps a small saving in cost, I don't see that they really have a whole lot going for them..... Sorry but that's my opinion :(
Re: Paddlewheels
« Reply #32 on: September 19, 2009, 06:52:15 AM »
hi Kim
I tend to agree with Eddy. In fact brass BA nuts and bolts are actually cheaper in bulk than the bigger nylon/delrin ones.
My preference for the perfect paddle wheel would be.
PVC turned hub (can be tapped for bolts)
Brass etched paddle pivots, control arms and rivet detail.
ABS/PVC or even wood Paddle floats.
Spokes in ABS or PVC.
Wheel rims in etched brass (if thin) otherwise PVC or ABS
and definitely brass nuts bolts and studs
« Last Edit: September 19, 2009, 06:53:50 AM by Stuart Badger »
Re: Paddlewheels
« Reply #33 on: September 19, 2009, 06:55:58 AM »
Eddy many thanks for your thoughts.
I have found a supplier that does M2 with similar/identical diameter/measurements.
The saving cost is significant and that's my reason for asking.
many thanks any other thoughts would be appreciated
P.S. - Interestingly the nylon bolts/nuts come with a tighter thread.
Re: Paddlewheels
« Reply #34 on: September 19, 2009, 07:01:36 AM »
At 1/48th scale an M2 nut would be about 10 inches diameter to scale. At 24th scale 20inches Dats BIG! :P
Harold H. Duncan
Re: Paddlewheels
« Reply #35 on: September 19, 2009, 07:16:49 AM »
You sure about that Stuart?
By my reckoning a M2 nut is around 4mm dia - so that in real life from 1:48 would give a 7.5" dia. nut (3.75"dia thread)
and from 1:24 would represent a real life 3.75" dia nut (1.875" dia thread)
could be wrong
kiwi
Re: Paddlewheels
« Reply #36 on: September 19, 2009, 07:23:39 AM »
I seem to be having trouble with my numbers today! My UNRESERVED apologies to all!
Perhaps building scale models is not an occupation I should indulge in!!!
Re: Paddlewheels
« Reply #37 on: September 19, 2009, 07:37:10 AM »
 :terrific :whistle :squareone
Re: Paddlewheels
« Reply #38 on: September 19, 2009, 07:54:39 AM »
Ok Guys it's late at night so forgive the maths,
I do appreciate the comments.
If i go for brass / metal it does make a big difference to the cost. The difference in size between plastic and metal head screws / nuts is 0.2mm, which in scale terms is arguable????
Question - what would be the ideal diameter 1 / 48 scale nut and bolt? Is such a diameter available in nuts and bolts?
Re: Paddlewheels
« Reply #39 on: September 19, 2009, 09:54:04 AM »
I put some items together with plastic and nylon nuts and bolts at one time for a theater prop. It went together in an hour, I then spent the next week re tightening and replacing loose and missing parts. When the production ended the prop-master presented me with a sledge hammer and told me to enjoy myself.
If I was going to use plastic and nylon nuts and bolts again I would glue everything together after installing them.
Re: Paddlewheels
« Reply #40 on: September 19, 2009, 10:05:57 AM »
Hi PD's.......Talisman....here is a link to a table on BA thread form.......I am building @ 1:24 & find 10 BA [1.7 mm diameter] suitable...this equates to a 40 mm diameter stud diameter
So you must answer your own question...........but I am guessing that 16BA may be suitable for 1:48 scale & should be readliy available in brass.....but they are tiny  :hammer
Only a few rules to follow....the higher the number = the smaller diameter.......the smaller diameter = the higher the cost - Derek  :towel
http://www.sizes.com/tools/thread_BA.htm
Re: Paddlewheels
« Reply #41 on: September 20, 2009, 05:40:34 AM »
Despite being disappointed about not being able to attend the paddler day some info regarding etching came through the door today:)
I have to say the samples do look impressive and the possibility of producing a fine set of wheels has cheered me up slightly.
Stuart many thanks for your thoughts on an ideal set of wheels i will use them as a reference / bench mark for my efforts. :)
P.S
 the poll has been altered to be visible - results look as i expected - Many thanks to all that have voted :)
Pics of samples -
« Last Edit: September 20, 2009, 05:44:09 AM by Talisman »
Re: Paddlewheels
« Reply #42 on: September 24, 2009, 10:03:28 AM »
A busy day today...
2. Sourced a supplier of M1 threaded rod , M1 nuts and bolts in quantity and cost that is not prohibitive to making the kits commercially
Hmm...
I received a sample of my M1 threaded rod today........ M10 they sent.... expecting this just to be a mistake i now find out that M1 threaded rod is hellish difficult to make for less than £50 a meter.....
Back to the drawing board...
Re: Paddlewheels
« Reply #43 on: September 24, 2009, 04:18:50 PM »
Sorry Kim........"only a few rules to follow....the higher the number = the smaller diameter.......the smaller diameter = the higher the cost"
I am not a machinist [since 40 years ago  ;D]....but I doubt that M1.0 diameter would be produced as threaded bar 1000 mm long..... :hammer..........Derek
Re: Paddlewheels
« Reply #44 on: September 24, 2009, 05:41:37 PM »
Hi Kim
I presume you're using 1mm rod (threaded) for the horizontal bracing and/or the paddle float pivot shafts?
I use 1mm rod too - threaded 12 BA (1mm rod being 40thou or exactly the right size for a 12 BA die). I would have thought that there should be plenty of small light engineering outfits able and willing to thread just the ends of short lengths to accept nuts (ideal job for a small capstan lathe). Or do you Need the whole length to be threaded?
