Author Topic: Valley Belle  (Read 5450 times)
Offline scotfriend
Valley Belle
« on: March 25, 2008, 02:03:26 AM »
Hi PD`s,
on saturday i bought this nice model of the Valley Belle together with two huge barges all together for 400,- Euro. Today i started to see what kind of RC and electronic parts are in the model. When i picked up the model there was an old Graupner S12 transmitter so i knew there are only such old RC-components. asfter i had removed the upper deck and the motor (monoperm super 12V) i found an waterpump and some cables but i dont know what they are for, so please have a look to the photos and maybe one of you can tell me how it is working.
Re: Valley Belle
« Reply #1 on: March 25, 2008, 02:41:34 AM »
Very very nice Hans.....   :bravo
It's impossible to tell what the pump is doing from the photos - Where do the pipes lead to? It appears they may exit at either side of the stern, so perhaps it was being used as a stern thruster to help with turning?
Offline scotfriend
Re: Valley Belle
« Reply #2 on: March 25, 2008, 03:56:03 AM »
OK,
as far as i can see one hose leaves the hull at the port end of the hull and the second is on the inside of the hull, could it be that it is a safety feature if water comes into the hull the pump removes it.
This is the only possible idea of this construction.
Regards Hans
Re: Valley Belle
« Reply #3 on: March 25, 2008, 04:06:59 AM »
OK,
Regards Hans
You're probably right Hans - My model of the Suter sternwheeler takes in water when going astern, through the holes that the pitman arms exit through. It's fine when going ahead.....
Re: Valley Belle
« Reply #4 on: March 25, 2008, 04:29:26 PM »
Hi PD's....I think you have hot the nail  :crash head Hans
in 003 jpg we see a blue outlined plastic mesh which appears to be captive - this certainly could be a filter element to keep weeds from the pump suction
in 002 jpg we also see to the lower left of snap...a dark/black round section [12 mm diameter?] vertical component which is hard wired  to the pump motor supply terminals...... :thinking...this could be a float switch......
Possibly time to get the BM SAABA multi meter out & trace the conductivity   :hehe or if all else fails...power up the battery & fill the hull cavity with clean water & see what happens  :terrific
« Last Edit: March 25, 2008, 04:35:52 PM by derekwarner_decoy »
Re: Valley Belle
« Reply #5 on: March 26, 2008, 04:35:11 AM »
I think Derek has it correct, It looks like a bilge pump. Probably the stern area around the rudders fills with water, and the two bare wires are sensors for turning the pump on. Looks like a Great Buy.
