Author Topic: Glass Fiber & Epoxy Resin Hull Reinforcing  (Read 3201 times)
« on: April 27, 2007, 04:09:12 PM »
Hi PD's - this is nearly  :offtopic ...but here goes
A twenty metre roll of 50 mm wide of what appears to be conventional translucent FLY SCREEN material... from your local hardware shop
Is the same size & mesh opening ....but it is a mono filament fiber glass 0.005" diameter PLUS it is self adhesive on one side only ...and @ $AUD4.00 per roll is pretty good value
This could be layered up X 3 or 4 thicknesses [out of phase or mesh] & would save countless tubes of SupA - GLU  :ohno & glued up  :rant fingers  +  :sob prior to the pouring of the liquid epoxy resin + hardner........ Derek
