This model is the old EDWARDIAN PADDLE STEAMER issued by PBM models from HA BLUNTs model shop in Mill Hill London for a very few years between I think 1978 and the earely 80s. It was a very good kit for its day and to my mind superior to the "plasiky" offerings of today.
I have built two of them and have a third unstarted which I got off ebay ( I have a very soft spot for this kit which can be altered to resembly a great many UK paddlers).
MODEL 1. I built as per kit with, you guessed a permanent limp after every turn!. As the sponsons are very close to the water, any list means that the gap between the box and the surface is too small for the box to "breathe" causing the box to fill with water and lifting the opposite paddle out of the water so that it cant lift any water to counterbalence the other side! (Phew). my partial remedy was as follows: cut out the paddlebox slats, allowing some air to enter
the box low down. Remove the walkways on top of the box and drill 2 small holes in the box top (about 1/8 ") Replace walkway making sure that air can get to holes. This allows some air to enter the box top, breaking the Hydraulic effect.
If you still get some listing, stop engines and gives a short burst astern, this should allow the water to drain from the box.
Add a small removable bulb keel as per model yachts , about 3" deep about the weight of 2 AA batteries. Use smaller reciever batteries to compensate for weight increase.
MODEL 2. As above, with the following alterations. Remove large areas of the bottom plank which allows batteries etc to be placed lower down and add a 1/2" balsa sheet to the bottom. This has two effects, lowering the weight assists stability and the extra plank increases stability so that ballasting can be added, in my case, a1/4" square strip of lead let into the new plank on the keel line. Result perfect stability.
MODEL 3. Will have much of the wood replaced by thinner section and some of the internal structure deleted as in some respects the kit is over engineered. This is a really pleasant kit to build and results in a very pretty model. Best of luck, Walter.
