Author Topic: gear and belt drives etc etc  (Read 7749 times)
« on: March 14, 2005, 08:20:45 AM »
Hi Guys,
I came across the following company tonight while wandering around the web... It looks like it could be a superb source for all sorts of drive components!
And best of all, they do a FREE catalogue, just go to their website and request one...
http://www.hpcgears.com/
« Reply #1 on: March 14, 2005, 11:16:11 AM »
That is useful, I see they have those toothed belt drives (used in printers and photocopiers) that should be ideal for paddle drives...
Drive Belts & Pulleys
« Reply #2 on: March 14, 2005, 04:54:00 PM »
hi Mick - model shops catering for cars sell the 6 mm wide segmented pulley belts & pulleys - so whilst the are not cheap they appear less expensive than the office supplies printers & scanners repair people here in OZ - Derek
« Reply #3 on: March 15, 2005, 09:25:08 AM »
That's interesting, I didn't know model cars use them...
S James Southern
drives, electric
« Reply #4 on: April 12, 2005, 11:23:20 AM »
To anyone who is interested, this has worked for me.  A 12v automotive wiper motor makes an inexpensive and easily available motor/reduction unit for paddle drive. Most are two speed, but the DC motors will work with variable voltage speed controllers as well...(the torque and rpm's are in the right general range). The ones for the rear windows and hatches are generally single speed and smaller in size. Mounted upside down with the motor below and the gearbox up, a low COG can be maintained. Hope this is helpful.
        James
Chain Drive???????????
« Reply #5 on: August 07, 2005, 02:37:06 PM »
hi PD's - here is a question best directed to Stuart [PS Reliant], but any other comment appreciated
Stuart - I am making quite a few assumptions here with your Reliant
1) paddle shaft chain sprockets 40 mm diameter?
2) engine shaft chain sprockets 15 diameter?
3) 2.7 : 1 speed reduction ratio?
4) 150 paddle shaft RPM = near 400 engine shaft RPM?
So irrespective of the accuracy of the numbers here, do these sorts of speeds create an unacceptable CHAIN NOISE?
5) what type chain drive [material & pitch] have you used in Reliant?
My reason for asking is that PS Decoy could be displayed with a viewable chain drive on the paddle shaft & I have considered the 0.1475" pitch S/S chain from SPD/SI & complementry chain sprockets - this chain has a UTS of 180 lbs, where as the nylon varient has a UTS of only 6 lb
I do remember some years ago you mentioned that one of the chain pinions [on an engine?] lost positive drive & you were to correct this with an alternate locking method etc   :music - Derek
Offline scotfriend
« Reply #6 on: August 15, 2005, 06:23:30 AM »
Have a look to the following company, OK i know its a German company but they sell a lot of interesting things. Gear parts, belts and microengines for a lot of applications,  www.lemo-solar.de
