Author Topic: Ships Wheel?  (Read 5553 times)
Ships Wheel?
« on: January 06, 2006, 05:09:47 AM »
I have to make a fairly large diameter ships wheel for the pilot house/bridge of my model of the Suter. That's the wheel used for steering, NOT the paddlewheel....
Has anyone made anything like that and could give some tips? The one I need to make is approximately 4" in diameter. I've searched the normal suppliers, but no-one seems to manufacture anything that large, so I'm stuck with making my own..... HELP! :-)
SSMA Bruce
Ships Wheel?
« Reply #1 on: January 06, 2006, 05:11:45 AM »
how big, how many spokes, how many grips?  Usually, spokes = grips.
Ships Wheel?
« Reply #2 on: January 06, 2006, 05:25:42 AM »
Quote from: "SSMA Bruce"
Typical - I put all my modelling stuff away for christmas, and now that I want to find the drawings I can't!
Anyway, taking a rule to the pilothouse, it needs to be 4" in diameter, with approx 16-18 spokes/grips.
SSMA Bruce
Ships Wheel?
« Reply #3 on: January 06, 2006, 05:32:32 AM »
1-2 inches and I'd just draw it out on piece of sheet basswood, scroll saw it out, then needle file the curves and details.   At 4", I'd turn the spokes on a lathe and build it the same way they did in the day.  I'd still use basswood, though.  Tough one.  Scan and post it when you find your drawings.
Ships Wheel?
« Reply #4 on: January 06, 2006, 05:42:25 AM »
Hooray! I found the drawings!
I've built to a different scale to the drawings, so please DON'T use them for dimensions! The wheel needs to be 4" in diameter from the tip to tip of the spoke/grips.
SSMA Bruce
Ships Wheel?
« Reply #5 on: January 06, 2006, 05:52:14 AM »
Yeah, this one is pretty straight forward.  I'd take a sheet of 1/4 inch basswood and draw the two rims at about 1/4 inch wide, plus the hub.  Before cutting, I'd mark out the spokes at one per 20 degrees.  I'd do it all by hand - no power tools.  Don't try to cut the rims/hub at the line, but just outside it.  sand it down to the line after cutting.  Use a pin vise to drill the majority of the spoke holes, then finish the rectangle with a file.  Turn the grips on the end of each spoke, or, use a round file to shape them by hand.
Basswood is optional.  I think its soft enough to be easy to work, but hard enough to not be too fragile, once finished.  You can stain and finish to suit.
towboatjoe
Ships Wheel?
« Reply #6 on: January 06, 2006, 08:18:19 AM »
Here you go Eddy. I took your drawing and made a template for you to use. By the way the grips are at 20 degree increments if anyone was wondering.
Ships Wheel?
« Reply #7 on: January 06, 2006, 09:42:33 AM »
Thanks Bruce and Joe - The help is greatly appreciated.
