Author Topic: Converting rotary motion to linear motion  (Read 2571 times)
ijigm
« on: June 20, 2005, 09:10:06 PM »
where can I find out how to? I understand rack and pinion but want to
use another method.
george britnell
« Reply #1 on: June 20, 2005, 09:10:24 PM »
What exactly do you want to do with it? Will you be
moving in just one direction or will it be a
reciprocating motion? One of the most common rotary to
linear motions is the scotch link. It uses a rotary
crank pin inside of a sliding block which rides in a
slotted link. It works fine but depending on rpm it
has great(poor)friction and wear properties. There is
also the common crankshaft with a pitman arm riding in
a set of guides.
gbritnell
Joe E Brown
« Reply #2 on: June 20, 2005, 09:10:43 PM »
If you're talking moving a sternwheel with realistic moving pitmans,
I have photos and a diagram for the one I built for mine at...
http://www.dragg.net/jbrown/construc2.htm
