Author Topic: Various  (Read 2027 times)
Various
« on: June 20, 2005, 02:56:37 AM »
on Wednesday, December 10, 2003 8:02 AM, tonymattson wrote :
> G'Day Derek, I read your latest email with great interest.
> So you have a new JR receiver. Is the 700 the really tiny 7 channel one? I bought one of those for my own use just a month ago and couldn't believe how small it was. >I'm 'blessed' with five sausage sized thumbs on each hand so struggle a bit with up to seven servo leads coming out of an Rx half the size of a redheads Matchbox. >Had no problems with it so far tho'.
Sure is small @ 1.84"x0.98"x0.61" but one of the minor issues is that the Futuba lead plugs I requested on my ACTion kits are 2.65 mm thick where as the JR receptcal is to suit 2.5 mm JR plugs & after you snip the lug on the Futuba plug, then sand the thickness to 2.5 mm then file two 0.5 mm face directional chamfers the plugs look a bit worse for it so will replace them all with original JR leads
> Absolutely fantastic to read that you're getting the right results coming from the new Rx ! - Did your JR suppliers provide any explanation as to why there were
> compatability issues? I'd love to know as I'm sure wld the rest of the PDers, esp. after our various postings :-)
Interesting point & the old engineering philosophy here Tony - never replace two things or systems together because if it dosn't work they will ony blame each other, so I took my 20 year old Futuba ESC & the new [three day old] JR kit in & questioned the six ratchet clicks in neutral position & stated that if I plug the same old Futuba ESC into my 20 year old Futuba R/C kit I get just three ratchet clicks in neutral etc etc - so after the usual [no we don't believe you, but will just try other R700FM Rx just to disprove you] & hey presto just three clicks in neutral, so I departed the store with the alternate Rx & that evening got my new ACTion Kits ESC to perform perfectly - I will post more on the sound effects modules when time permits
> Ps: I've just about completed my sponsons after some false starts and rework. The outboard storage compartments on Reliant have given me a few pauses for thought > but are finally there. As have my paddlewheel rims, for that matter. I was originally hopeful of feathering the wheels but at 1:32 scale and with no practical engineering > expertise (or lathing/milling machinery) I've reluctantly opted to go for fixed paddleboards.
> Shld be no adverse impact on performance at this scale, but the look is not quite as detailed as I would like. Perhaps I'll revisit this in future when I have a tad more
> expertise and equipment - cheers - T
Good to hear of so much progress here Tony & I note your recent questions & response between Stuart & yourself etc & one of the real benefits of belonging to PD's - constructing feathering paddles @ 1:24 or @ 1:32 would still require the same access to machining or tooling facilities - so being realists if they are not readily available we just improvise & if weight permits you can simulate the bulk of the feathering wheel connections & rods & pins etc [ala fixed] only the water will know - regards Derek
