on Tuesday, December 02, 2003 8:41 AM; Tony Mattson - wrote a lot of things!!!!!!
>I'm a law-abiding electronic simpleton, so when I read that it was ideal
>to install a separate motor drive battery for each drive train, that's
>what I did. So now I have two 12V batteries to find space for inside my
>Reliant. I defer to Craig Talbot and other more electronically inclined
>groupies for a coherent explanation as to what the reset problems might
>entail.
>If using sound cards then "ideally" each motor has its own steam engine
>sound simulator card connected to its own power supply and ESC so that
>each sound varies proportionate to each motor. (I haven't tested this
>yet but anticipate some interesting harmonics being produced when
>turning as the sounds go in and out of phase). I think this would also
>point to the need to split the power sources for your two motors.
now hold on here !! - last week you suggested using the third
or centre mixer connection [relative to actual throttle
position but not proportionally controlled] & now you are
suggesting MORE TWO LOTS of things !!!!!! - last night I weighed
the seven electrical box's to date @ 800 gms & thats without
the speaker!!!!!
Might you be able to convert to 2 x 6V 7AHr batteries for your motors
instead? I have a couple of Yuasa's this size and they have a nice slim
profile to help keep weight down low in a model.
You might also be able to do away with the separate 12V battery
completely if you are cunning with your 2 x 6V batteries:
* connect these serially to get a 12V supply
* take centre taps for your independent 6V motor supplies
thanks - I take your points, but am using the 12 V x 3 A/H
battery also as ballast down aft, but also cross connecting
these would pose charging issues
The draw from the sound simulators and smoke generator wouldn't be much
more than 700mA so shouldn't represent too much of a drain relative to
paddle motors under load.
Although I'm a steam virgin, I'm inclining to think that Stuart has gone
down the simpler route by using a live steam plant and twin engines in
"Old Trafford", compared with us 'electroheads'!
again - I couldn't disagree here - I thought it was going to be
so simple - & thanks again for your valued comments - Derek
