Hi PD's, I am stumped - opened the case & no connections for + & - so sorry
but I must be a thick mechanical person & have previously acknowledged
little electrical sence, so have ear marked this one to Tony in NZ as he has
mastered the art of connecting & getting the P40 mixer to work
so sorry to bore others but it's like this when I read the schematic on page
2
1) SW1 = double minature motor reversing switches to be used in final set up
& to negate reversal of hard wiring
2) LED = power indicator
3) Conn4 = power output supply to motor 2 [page 1 text says output
connector]
4) Conn3 = power output supply to motor 1 [page 1 text says output
connector]
5) Conn2 = signal output to rudder servo
6) Conn1 = power output to center motor [if used] - so will be used
signal/power output to P56 steam sound generator
7) Wiring connection loom & plug No 1 to receiver channel 1 for rudder
Wiring connection loom & plug No 5 to receiver channel 2 for throttle
So I am OK with 1) >
inclusive but it's here where it gets good because
this leaves me with
9) a + red wire & a - black wire from my Futuba digital speed control that I
do not know where to plug in
10) the Futuba digital speed controller also has the little three pin
connection wire that I do not know where to plug in
Again I am stumped - Derek
> Craig came back with the message below but it dosn't make sence [to me]
> Derek
> Your Speed Controllers ans Steering Servo PLUG TO THE PINS STICKING UP ON
> THE P40 MIXER. THEY PLUG IN THE SAME WAY YOU WOULD PLUG THEM IN TO A
> RECEIVER. The two leads go to the Steering/Rudder channel (1) and the
> Speed/Direction channel (2)
> OK?
> Craig
>Original Message-----
> From: Derek Warner [mailto:derekwarner@bigpond.com]
> Sent: Friday, 21 November 2003 7:01 p.m.
> To: actionkit UK
> Cc: Tony Mattson
> Subject: P40 Mixer
> Craig - looks like I spoke too soon & the first item I look at I get
> stumped!!
> Figure 2 schematic [page 2] for the P40 mixer top left hand side shows
> three vertical down arrows,
> - black, + red, white/yel/orange/blue & these are in line with the
> respective pin sets - however the
> P40 mixer case appears to be glued together & I can only assume the
> three connection points are
> inside the case [as is with the other component box's which are not
> screwed or glued together] - I
> also note that the circuit board is loose in the sealed case - is this
> normal?
> I have re-read [page 3] by Dave Milbourm but don't think I have missed
> any thing here
> Your earliest advice appreciated - Derek
